Water leaking below the front floor - Toyota Camry 2000 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2007, 02:13 PM   #1 (permalink)
View kayjee's Photo Gallery
I bought a 2000 Toyota Camry last month, and have been driving since then. No major problems except probably the muffler - the car started getting noisy on acceleration about 2 weeks ago (I was told by the dealer that it was not harmful, but I would need to fix it to get rid of the noise).
Today morning, I saw that there is a puddle of colorless odorless liquid (I think it is water) tricking from beneath the car, below the front floor. A google search and I found out there could be 3 possible reasons for a water leak: wiper system, the AC and the radiator system. While the first two are ok, the 3rd could be serious, is it? Is water dripping due to the AC normal? Can it be due to something else? How can I find out the reason for this water leakage before visiting the auto repair shop or the dealer? Please help.
kayjee is offline   Reply With Quote
Old 06-26-2007, 02:21 PM   #2 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
From the area your describing it sound like normal A/C condensation dripping. Perfectly normal.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 06-26-2007, 02:22 PM   #3 (permalink)
View J708's Photo Gallery
Water dripping due to AC is normal. As you realise it stops after time. But if it doesn't stop after time then I doubt its from AC. Now I started getting a leak a year back, and it turns out my power steering pipe had a leak, which made my steering so stiff in turning. But I doubt thats your case. Thats all the info I can provide you with.
Camry 1996 2.2L - 121,000+ miles
J708 is offline   Reply With Quote
Old 06-26-2007, 02:22 PM   #4 (permalink)
View freestylez's Photo Gallery
hey, if you had your AC on, water will always drip out
if you stay in one place for a long time, you will definately see a puddle of water, its normal
if your AC was off, there might be a leak
2000 CAMRY CE
freestylez is offline   Reply With Quote
Old 06-26-2007, 02:31 PM   #5 (permalink)
Thanks all. I will check without turning the AC on today.
Old 06-26-2007, 03:03 PM   #6 (permalink)
Gameroom cash: $303055
"I saw that there is a puddle of colorless odorless liquid (I think it is water) tricking from beneath the car, below the front floor"
This is normal condensation form the A/C system being expelled from the car. The A/C system dehumidifies the air in the car. It turns this in to water which has to exit the car in some way. There is a tube that runs from you A/C system to the outside of the car to expell this water. It's perfectly normal.
Mike
Old 06-26-2007, 03:11 PM   #7 (permalink)
Thanks Mike,
But I haven't noticed so much water before. Also it was dripping after the car being parked for nearly 3 hours. I will come to know if it is the AC condensation once I keep the AC off for a few miles and check, isn't it?
Old 06-26-2007, 03:58 PM   #8 (permalink)
Originally Posted by kayjee
Thanks Mike,
If it's still dripping 3 hours later the drainage tube might be partially clogged. Take it to a shop and tell them what's happening. They will put the car up on their lift and blow out the drainage tube with compressed air. This is a fairly common occurance that takes about 5 minutes and some compressed air to fix.
Mike
Old 06-26-2007, 04:08 PM   #9 (permalink)
Thanks Mike..that explains it.
Old 06-27-2007, 06:39 PM   #10 (permalink)
You're welcome.
Mike
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
INFO: 1996 Toyota Camry Specifications Ratko 3rd & 4th Generation (1992–1996 & 1997–2001) 22 08-08-2009 05:09 PM
Having trouble with alarm system in 2000 Camry LE JavaFanatic 3rd & 4th Generation (1992–1996 & 1997–2001) 9 03-12-2005 12:16 PM
My leaking '98 Camry PRG 3rd & 4th Generation (1992–1996 & 1997–2001) 5 02-26-2005 12:05 PM
5s-fe leaking front pipe bronzemaxell Camry & Solara Lounge 1 10-23-2004 03:37 PM
