Wiper motor problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2007, 08:47 PM   #1 (permalink)
View Albetime's Photo Gallery
4th Generation Wiper motor problem
1997 Camry LE----I have 2 problems with my wiper motor, first the wipers will not return to the proper stop point and second the iterval (delay) function does not work. The wipers work normally except for these 2 problems. I read that if the wipers dont return to the proper stop position then replace the wiper motor, has anyone tried to repair the motor/internal switch?
What and where is the interval module located?
Thanks
Albetime is offline   Reply With Quote
Old 07-01-2007, 07:54 AM   #2 (permalink)
Wow.....thought someone would have input on this problem. I have searched similar posts but they dont really apply. Has anyone had this type of problem? Thanks
Old 07-01-2007, 08:26 AM   #3 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
Thanks
(Assuming the switch is good) If the wipers dont park properly, the motor needs replacement. But in your case with the INT not working, the switch may also be defective as well. So I would start with a motor first.
1992 Lexus ES 300 5 Speed -My baby- 111K - Slightly modded 3VZ-FE - Denso Iridium plugs/Vitek Wires - KYB Struts & Mounts - Whiteline RSB
2000 Toyota Solara SLE V6 Auto 3100 miles on the clock (Summer ride)
92ES5sp is offline   Reply With Quote
Old 07-11-2007, 09:05 PM   #4 (permalink)
Thanks 92ES5sp
96 Camry Wiper Relay DD 3rd & 4th Generation (1992–1996 & 1997–2001) 3 12-02-2008 02:50 PM
92 le Wiper problem (advice needed) mikerowesoft 3rd & 4th Generation (1992–1996 & 1997–2001) 6 12-12-2007 09:32 AM
Front Wiper Question johng1021 1st Generation (2001–2007) 2 03-20-2007 01:49 PM
FS - True single wiper conversion - Mercedes benz 190E wiper unit S14 Car Parts for Sale 0 01-24-2007 02:48 AM
89 camry wiper question dallison 1st & 2nd Generation (1983–1986 & 1987-1991) 2 02-15-2004 01:35 AM
