Gauge install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2007, 04:57 PM   #1 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Gauge install
Ok I got my sandwhich adapter today and got all the gauges up and running...
My oil pressure PSI @ idle is around 10-15. Does that sound about right?
Oil temp is around 180
Curry is offline   Reply With Quote
Old 06-27-2007, 05:07 PM   #2 (permalink)
Sleepin zZzzzz
360glitch's Avatar
View 360glitch's Photo Gallery
What all gauges did you install? Boost, oil pressure, and oil temperature? How long did it take?
'01 Avalon XLS - Project Log
'92 Eagle Talon TSi AWD - Project Log
360glitch is offline   Reply With Quote
Old 06-27-2007, 05:30 PM   #3 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
speakin of gauges, i see you have blue/red speedo+tach ... im thinkin about gettin those black reverse gauges from PCP ...
are they easy to install? i think Adam is gonna write me up a DIY [minus the wiring part since he's never done it]
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 06-27-2007, 05:44 PM   #4 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
talk about off topic thread jack
WhiteRabbit is offline   Reply With Quote
Old 06-27-2007, 06:54 PM   #5 (permalink)
Curry's Avatar
Ok. Ready. Here we go.
Gauge installation wasn’t easy but it wasn’t super hard. Read the instructions and you will be fine.
The gauges I hooked up were boost/vacuum, Oil pressure and Oil Temp. Im still waiting for my wideband to get here which should be in another hour or two.
Basically for the install here’s what I did.
  • Each gauge has a + and – for lighting that’s a no brainer.
  • Installed the vacuum line according the install instructions
  • pulled off the oil filter and installed the sandwhich adapter
  • ran the temp sensor and oil pressure line from the adapter to the gauges
  • turned the car on.
  • I made a mistake by not tightening the adapter properly and had a very tiny leak but I fixed it. No big deal. Drove around and the car is fine.
Here is what I got from the readings:
Boost/Vacuum: Starts @ 0 PSI. On WOT it goes up to 20 PSI (few more days and its gonna start showing boost =P)
Oil temp: Goes up and stay around 180-190F
Oil Pressure: Starts @ 50-60 PSI drops to 10-15 PSI @ idle and goes up and down while driving.
Venom: those are pretty easy to install. They slip right over the needles. Remember the postion of your gas in case you move it!
Rabbit: im going to post those pics in the FS section now ; )
Old 06-27-2007, 07:31 PM   #6 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $359160
iTrader Score: 13 reviews
oil pressure sounds fine- what kind of oil are you running? My oil pressure runs a bit higher, but it's colder here for the most part. Once the oil is fully warm, then I show basically the same pressures. at WOT though, the pressure can get to around 80psi or so.
oil temp sounds fine as well. In hot weather or after hard runs, I can top out at 210F.
the only thing that I can say that isn't right is your vacuum pressure- are you sure that you didn't get the backwards? At idle, it should be at 20 and then at WOT, it should be at 0 vacuum. After that, it hits boost.
My suggestion after this would be to get yourself a tranny oil temp gauge as that is what you will have to worry about from here on in...
HaHa
Old 06-27-2007, 07:34 PM   #7 (permalink)
Venom_5's Avatar
^ x2 to the tranny temp gauge ... i know a few guys that have to watch their tranny temps like crazy - and they even have aftermarket tranny coolers
and thanks for the info about the gauges
Old 06-27-2007, 08:34 PM   #8 (permalink)
Curry's Avatar
Yea i have one of those on the way.
I dunno it reads 0 @ idle and wot it reads 20... I hooked everything up properly, i have no leaks or anything....
Where do you have yours hoooked up?
Oh yea king, let me know when you get a chance to send those pics, if you wanna email them to ill PM you my email address. I'm gonna try to install the fuel stuff tomorrow.
Old 06-28-2007, 12:12 AM   #9 (permalink)
View 94CoupeV6's Photo Gallery
I know with my vac gauge, it reads about 15 psi at light throttle and 0 at WOT. The lighter you place your foot on the gas, the high psi reading. That's how it is supposed to be.
What vacuum line did you tap into?
94CoupeV6 is offline   Reply With Quote
Old 06-28-2007, 12:14 AM   #10 (permalink)
Venom_5's Avatar
somethin's definitely weird with ur vac pressure ...
20psi at WOT and 0psi at idle is backwards like King said - unless you tapped into the wrong side of the system? idk if thats possible, but somethin has gone funky
Old 06-28-2007, 12:57 AM   #11 (permalink)
TN Pussy Man
hey man....I sent you the pics (only two since it's pretty simple) through PM- you didn't get it? I'll try it again...
and like venom is saying, I think that you may have installed your vacuum line on to a wrong port or something.....the only time that vacuum would be 0 at idle and vacuum is gained when on the throttle is running a hose pre-throttlebody (I think....)
HaHa
Old 06-28-2007, 01:04 AM   #12 (permalink)
Curry's Avatar
nothing in the PM box =( I'll PM you my email.
I spoke to toys, i forget why but it wont work if you split the line at the throttle body you have to get it from the intake manifold side.
i'll try that tomorrow and see how that goes.
Old 06-28-2007, 01:16 AM   #13 (permalink)
TN Pussy Man
did you get my pm with the picture links?
and lol...yeah...that would your problem right there. You can either take it from the intake manifold or even off the fuel vacuum lines.
HaHa
Old 06-28-2007, 01:24 AM   #14 (permalink)
Curry's Avatar
Yep got the PM, just replied.
Cool, im gonna fix that up tomorrow.
Thanks!
Old 06-28-2007, 07:07 PM   #15 (permalink)
Curry's Avatar
Ok I tried earlier today to move the vacuum lines around to get the gauge to work properly. I tried 2 of the fuel vacuum lines and another one for i dont know what.
When I hooked them up the gauge still read 0 and if I rev nothing happens...
any ideas?
I should have took some pictures of where i tapped. bah. Ill try again tomorrow. I cant really get to the car ATM.
Rise from the Dead (and glow gauge install) Altarium 3rd & 4th Generation (1992–1996 & 1997–2001) 5 07-27-2009 03:02 AM
Tranny Temp. Gauge install? WhiteRabbit 3rd & 4th Generation (1992–1996 & 1997–2001) 20 07-05-2007 09:17 PM
Triple Gauge Pod Install DAMON Camry & Solara Lounge 24 06-10-2006 04:40 AM
Boost gauge install Q Strat42586 MR2 Forum 4 01-10-2005 03:20 PM
Indiglo gauge install. Please HELP! cheeba Camry & Solara Lounge 10 10-18-2003 07:25 PM
