Wheel Question! Urgent - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2007, 07:24 PM   #1 (permalink)
View chopstickz's Photo Gallery
3rd Generation Wheel Question! Urgent
On my 93 Camry the tire size is 195/70-14. I am in need of tires right now because I can see the wires from inside -_-... My mom has her stock 03 Camry Le wheels which are 205/65-15. I wanted to know if they will rub or scratch if I take tight turns or go canyon carving.
Also, would there be any problem running those 03 camry wheels when the car is lowered with Tokico Blues and Intrax springs? I don't want the tires to scratch or anything.
chopstickz is offline   Reply With Quote
Old 06-27-2007, 07:35 PM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
they should be fine ... i dont know about with the intrax drop, especially since Intrax doesnt always drop evenly
but with a 15" rim, you wont bottom out ... thats for sure
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 06-27-2007, 08:55 PM   #3 (permalink)
cmon! more people
Old 06-27-2007, 10:41 PM   #4 (permalink)
Tom 2000's Avatar
Gameroom cash: $189850
View Tom 2000's Photo Gallery
205/65R15 will fit fine as the V6 models from 93 came with that size as well. However, the those tires are slightly larger in diameter. The speedo (probably the speed sensor, not the speedometer) for the V6 is calibrated to take into account the larger tire diameter.
The 205/65R15 will still work. Your speedometer will just read a little slower
Take a look at this link and play with it.
http://www.rims-n-tires.com/rt_specs.jsp
What you want are 205/60R15s. It won't rub, but if you're going to go to the tyrouble of lowering your car, I would get some bigger wheels (16s or 17s). 205/55R16 tires will work and the tires are still affordable. 215/45R17s are still the same diameter and should work, but the tires get a lot more expensive.
Keep in mind you need to get the appropriate sized wheels to fit any of these tires.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
wheel question for 06 tacoma sr5 access cab nads755 2nd Generation (2005+) 5 03-14-2010 05:34 AM
'07 steering wheel tilt question costanza 5th & 6th Generation (2002-2006 & 2007-2011) 7 03-10-2007 12:26 PM
Wheel Stud Question GrayGen4 3rd & 4th Generation (1992–1996 & 1997–2001) 2 01-29-2007 02:11 PM
putting steering wheel back on question ridebmx 89-95 Toyota Pickup/Hilux 3 01-20-2007 09:37 PM
question about TRD steering wheel ID Camry & Solara Lounge 1 08-19-2002 10:49 PM
