Tranny question and fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2007, 04:41 PM   #1 (permalink)
View sampsongrsk's Photo Gallery
4th Generation Tranny question and fluid
I have searched the forum for this and havent heard anything in real relation to it...
I have 123k miles on my i4 98 AT, and i plan on changing the filter/screen along with most of the fluid and the gasket. I bought the car at 120k and dont know if the fluid has ever been changed, it is brown in color and doesnt smell like it has gone bad. I plan on puting in some synthetic blend Mercon V ATF, the penzoil bottle says it is compatable with Dextron III and II so should this be ok? (just cuz the bottle says so doesnt always mean it is). And if anyone has any link to an easy step by step for a drop pan and refill DIY please post a link.
Also as far as i know i need a driver side door actuator (automatic lock wont work but key will). I am having a hell of a time trying to find a replacement for it but i have found some so called "universal" actuators online for 10 dollars, does anyone have any experience with this stuff and do they actually work? thanks in advance
sampsongrsk is offline   Reply With Quote
Old 06-29-2007, 09:22 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
I have a 95 camry with A/T, and I have been running Valvoline Max Life Dexron III, and it works great. I don't know how Mercon would work considering that toyota says to use Dexron. I would just go with Dexron to be on the safe side. As far as the lock actuator, universal = cheap crap that doesn't fit. Do it right and get the correct actuator either online or at a junk yard. It will make life alot easier.
95PimpingCamry is offline   Reply With Quote
Old 06-29-2007, 09:35 PM   #3 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
No and a hell no....
If you use mercon your tranny is gonna go bad REAL fast. If the fluid is brown, its pretty badly burnt and or is the original fluid. If you flush it, it might make things worse.
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 06-30-2007, 12:41 AM   #4 (permalink)
View toyomoho's Photo Gallery
There is Mercon which is compatible with Dexron. There is also Mercon V which is a different fluid, don’t use Mercon V in place of Dexron..
Trans/diff fluid question - '96 LE 2.2L w/A140E Truthunter 3rd & 4th Generation (1992–1996 & 1997–2001) 11 12-05-2007 01:22 PM
Tranny fluid question. djarno 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-04-2006 03:58 PM
Tranny fluid change? megamac83 Camry & Solara Lounge 17 04-11-2006 08:14 AM
dumb question: tranny fluid and filter amosbench Camry & Solara Lounge 3 05-29-2005 02:25 PM
Transmission Flush Scare 03ESimposter Camry & Solara Lounge 14 12-07-2004 01:19 AM
