Do I have an O2 sensor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2007, 05:56 PM   #1 (permalink)
sae
View sae's Photo Gallery
hello,
My catalytic converter on my '95 V6 camry - non california emissions type - is in need of replacement. I called a local shop that was recommended to me and they said that I could just get rid of the cat converter all together and replace it with a straight pipe for $55 or replace the cat with a resonator for $110. This is in Canada so we can get away with some less restrictive emission requirements. The guy I talked to said that the only way I could completely eliminate the cat converter is if I don't have an O2 sensor by my cat converter. So...does a '95 camry V6 have a cat converter O2 sensor?
sae is offline   Reply With Quote
Old 06-29-2007, 06:00 PM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
dont delete your cat ... and you already have a resonator after your cat
if anything, get a hi-flow cat and 2.5" piping
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 06-29-2007, 06:40 PM   #3 (permalink)
sae
I am not trying to go for power here, I am going for cheap
Old 06-29-2007, 06:58 PM   #4 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
I'm not to sure but I figured cause it's obd2 that it will probably have an o2 sensor down there too.
felonyr301 is offline   Reply With Quote
Old 06-29-2007, 06:59 PM   #5 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
you have a post-cat 02 sensor
if you straight pipe it, you'll both get a CEL and fail emissions
though if you have your way of getting around emissions testing, you can pick up an 02 simulator that will send a fake signal back to your ecu
HaHa
Old 06-29-2007, 07:15 PM   #6 (permalink)
Venom_5's Avatar
if u want cheap, get an OEM cat ... they arent that expensive
Old 06-29-2007, 07:17 PM   #7 (permalink)
felonyr301's Avatar
Tell him how much to replace for the cat only. You don't need a new resonator.
Old 06-29-2007, 07:28 PM   #8 (permalink)
sae
new cat is $305 + tax...very reasonable really.
Old 06-29-2007, 07:37 PM   #9 (permalink)
sae
What advantage would there be to that? Doesn't the post O2 send the signal as to how lean / rich it's running?
Old 06-29-2007, 07:47 PM   #10 (permalink)
TN Pussy Man
the advantage would be that you won't have to have a cat
HaHa
Old 06-29-2007, 07:48 PM   #11 (permalink)
sae
doesn't that mess with how the motor will run?
Old 06-29-2007, 07:54 PM   #12 (permalink)
felonyr301's Avatar
that's what the o2 simulator is for, it just sends a fake signal saying it's a OK.
Old 06-29-2007, 07:58 PM   #13 (permalink)
sae
I understand that, but the O2 sensor must do something...so if I have one that is always sending an "OK" signal what am I missing out on?
Edit: never mind this question. I did some googling and I found out that the O2 sensor before the cat is used for the fuel/air mixture and the one after the cat is used only to tell if the cat has gone bad. Since I only have the one after the cat, an O2 simulator seems like it would work for me.
Old 06-29-2007, 10:41 PM   #14 (permalink)
sae
Is it usually considered a good idea to check your sensors when you change your cat? How can you check the O2 sensors to make sure they are good?
Old 06-30-2007, 06:31 PM   #15 (permalink)
sae
I have decided that I will be installing a cat...my friend has done a few himself so he's gonna weld it up for me and I can buy a generic cat for $100 or a direct fit for the toyota for $160. I was thinking of going with the generic one and just getting any pipe adaptors that I need. Is the exhaust size 2 3/8" outside diameter?
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
