Rebuildable struts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2007, 01:31 AM   #1 (permalink)
View rev_rock's Photo Gallery
Rebuildable struts?
I'd like to put new struts on my '93 Camry. I've seen ads for strut cartridges, but they say that they are only for rebuildable struts. How can I tell if mine are rebuildable or not. If they are, I'd have no problem doing it. I just don't want to buy the things and then find out that I've got the wrong ones. As far as I know, I've still got the original struts. I bought the car from the original owner, and she didn't say anything about ever replacing them.
Any tips?
rev_rock is offline   Reply With Quote
Old 06-30-2007, 08:58 PM   #2 (permalink)
Unco's Avatar
View Unco's Photo Gallery
from memory, the strut insert (shock absorber) part of the strut assembly is held in place by a retainer collar that can be screwed on/off.
you'll need to lift the bottom part of the dust rubber boot to see if this retainer collar is there. if it's not, then you have a sealed strut and you'll need to replace the whole strut assembly.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 06-30-2007, 10:58 PM   #3 (permalink)
Thanks, I'll have to check it out!
Old 06-30-2007, 11:03 PM   #4 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
Camrys made in Japan had rebuildable struts from the factory. Camrys made in Kentucky had sealed struts which you have to replace the whole strut assembly. If your VIN starts with a J, then your car was made in Japan. If it starts with 1 or 4, it was made in the Kentucky (U.S.)
Only exception I have seen are SE models made in Kentucky (had rebuilable struts).
One way to check is to jack up your car and peek at the strut assy inside the spring. If you raise it high enough, you'll see the shiny rod get exposed. If you see what looks like a cap at where rod comes out of the strut housing, then you have rebuildable struts. That cap is what you unscrew to remove the strut cartridge.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is online now   Reply With Quote
Old 07-01-2007, 12:47 AM   #5 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
Not true 95-96 models are sealed and mine is a Japan built 95 Camry. I thought 92-93 were unsealed and early 94 were unsealed and later 94 plus 95 and 96 were sealed.
felonyr301 is offline   Reply With Quote
Old 07-01-2007, 07:56 AM   #6 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
Just put KYB struts on it. Its worth it. There is no need to replace the springs unless you want a drop or they are broken (Which is unlikely, its a Camry not an Escort)
Ill be doing this on my ES 300 (which is a Camry) and the struts are servicable.
1992 Lexus ES 300 5 Speed -My baby- 111K - Slightly modded 3VZ-FE - Denso Iridium plugs/Vitek Wires - KYB Struts & Mounts - Whiteline RSB
2000 Toyota Solara SLE V6 Auto 3100 miles on the clock (Summer ride)
92ES5sp is offline   Reply With Quote
Old 07-01-2007, 06:35 PM   #7 (permalink)
Unco's Avatar
that's not what he's talking about though.
the struts themselves (NOT the strut + spring) can be either sealed units or they could have inserts that can be replaced. rev_rock is referring to the strut inserts.
please take a look and verify which struts I have MonsoonP 3rd & 4th Generation (1992–1996 & 1997–2001) 7 09-15-2006 03:59 PM
Rattling Sounds in rear...Struts? s6arface Camry & Solara Lounge 1 05-26-2005 09:44 PM
My new struts any good? Voodoo.Priest General Discussion 10 01-25-2005 09:39 PM
" K Y B " struts vs. Toyota/Lexus struts 93 Camry LE V6 General Discussion 6 12-13-2003 12:21 PM
Toyota/Lexus struts say "TOYOTA" & "KYB" on them. Thought they were differe 93 Camry LE V6 Camry & Solara Lounge 5 12-12-2003 11:19 PM
