1995 camry CEL - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2007, 07:38 PM   #1 (permalink)
geocull04
View quadracerscull's Photo Gallery
1995 camry CEL
I have a check engine light on constantly. I've tried jumping the terminals TE1 and E1 but the CEL doesn't flash. What am I doing wrong? I've followed all the directions posted on this site.
quadracerscull is offline   Reply With Quote
Old 07-01-2007, 01:00 AM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Make sure that you have a good electrical connection when you jump TE1 and E1, then you have to put your key in the on position without starting your engine. That should work, oh and I always use the terminal under the hood, not under the dash.
95PimpingCamry is offline   Reply With Quote
Old 07-01-2007, 07:00 AM   #3 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
You can always go down to Auto Zone or other auto store and have them read the code for free.
geoff5093 is offline   Reply With Quote
Old 07-01-2007, 07:49 AM   #4 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
If its a 1mz-fe engine it has OBD II. Youll need a scan tool.
If its a 5s-fe it should work on a 95. 96 and up vehicles are OBD II equipped.
1992 Lexus ES 300 5 Speed -My baby- 111K - Slightly modded 3VZ-FE - Denso Iridium plugs/Vitek Wires - KYB Struts & Mounts - Whiteline RSB
2000 Toyota Solara SLE V6 Auto 3100 miles on the clock (Summer ride)
92ES5sp is offline   Reply With Quote
Techna-fit Brake/Clutch Line Group Buy: All Makes/Models raptorracing Supporting Vendor Sales 230 08-27-2007 12:22 AM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
