headlight reto guestion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2007, 03:58 PM   #1 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
Question headlight reto guestion
ok so after MONTHS, im finally puttin the projectors in my headlights. but, like everything else ive done so far, ive run into a snag. i cant get the damn lenses off. i bought the depot clear but they almost seem glued on. how did yall do it? and yes, i removed the clips on both top and bottom(someone was gonna ask that i just know it ). any help is great.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 07-02-2007, 04:16 PM   #2 (permalink)
Gameroom cash: $283230
View LE05's Photo Gallery
there is a hard sealant in between the lenses and the housings... you will need to heat that sealant up to soften it. oven or heat gun works best.... personally i prefer the oven, as it evenly heats the headlight. if you're using the oven remove all meltable plastics (ie rubber grommets, caps, vent covers, etc), preheat the oven to 300 (temp can vary on preference) then turn it OFF. do not put your headlight in with the oven still on. with the oven OFF and preheated, put your headlight on a baking sheet or something similiar into the oven for 10 min. take it out with oven mitts then start prying away! you may need to repeat the oven step as the sealant cools.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 07-02-2007, 05:47 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
ha, an oven, never thought of that. ill give it a try.
R.I.P.
Car Domain:
Old 07-02-2007, 06:55 PM   #4 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Don't try and take the lens apart from the housing before heating the butyl sealant... You're gonna give yourself a hernia like that.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
[UPDATED w/ more photos!!] Gen 3 new cystral headlight housing arrived (w/ pics) bowen 3rd & 4th Generation (1992–1996 & 1997–2001) 62 10-09-2006 11:01 PM
Seperating 02-04 Camry headlights italia490 5th & 6th Generation (2002-2006 & 2007-2011) 1 12-17-2004 12:18 PM
my driver side headlight is really crooked TypeZer0 Camry & Solara Lounge 6 09-09-2003 09:15 AM
