Originally Posted by jhein39
Sorry I didn't mention...ya it has high mileage! I replaced the PCV valve and for the first 30 seconds after starting it...everything appeared fine...then the smoke came again. The smoke continues to come out of the exhaust while running and it seems to be running just fine.
If the blue and white smoke
continues to come out of the exhaust as you drive, then it's probably worn piston rings that's causing the problem. This means it's time for an engine rebuild or a replacement engine from a salvage yard with a lot less miles. Or, you can just keep driving it for a while and continue to monitor the oil level more frequently. Again you can see how quickly the level drops to where you need to add oil. If it is worn rings causing the problem, the oil level will drop rather quickly. Some people can live with adding a quart every 500 miles or so. It's really up to you.
Good luck.
Mike
