Just turned 200k....what now?
2000 LE V6 AT. Just turned 200k, goal is 300 which I will see in 3 years. Other than the typical wear items, what should I look to replace? The only thing done so far has been timing belts and water pump (during belt change). Tranny has about 120k, was replaced with a low milage used unit when I hit a rock on my commute (cracked the case). I'm thinking items like fuel pump, wheel bearings, struts, etc....
my commute: 80 miles one way, all but 5 miles is at 75mph. Oil (Valvoline Max Life 5W30)changed religiously at 5k miles, and it always looks fresh, never looses any between changes. Consistant 27-28 mpg.
