rear drum shoes break - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-04-2007, 11:35 PM   #1 (permalink)
View 1996camry's Photo Gallery
I have 96 Toyota Corolla and it need rear brake shoes replaced.
I took the brake shoes apart but I heard the brake shoes has the long and short. is that right? how can you tell which one is short or long? when you install the brake shoes, how do you know which short or long to install on the right or left of rear brakes?
1996camry is offline   Reply With Quote
Old 07-05-2007, 12:02 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
the brake shoes should be the same size...
HaHa
Old 07-05-2007, 07:13 AM   #3 (permalink)
does the brake shoes rear install one up and one down? i bough brake shoes from Autozone but when i check, it doesn't match with the old brake shoes on the rear car...the car bought from the dealer (used)...and the brake shoes wear off... is there way you can match it up when take apart? do measure length??
Old 07-05-2007, 09:09 AM   #4 (permalink)
Unco's Avatar
View Unco's Photo Gallery
no. while the metal part of the shoes are probably the same size, you'll find that usually, with rear drum brakes, the brake lining itself sits on a different portion of the metal shoe depending on whether it's the front or the back shoe.
how do you find out which one is the 'long' one? pull the old one out and compare it to the new one! put them side to side and compare how far up or down the shoe the lining sits and put the new shoes on in the same way as the old ones were.
on a side note, next time you might want to post corolla questions in the corolla section of the forum.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 07-05-2007, 09:12 AM   #5 (permalink)
Unco's Avatar
i don't follow you. you bought a car from a dealer with no brakes??? i might be able to help you, try explaining it to me like i was a 10 year old.
Old 07-05-2007, 12:08 PM   #6 (permalink)
View keba's Photo Gallery
I have done this before.Usually the brake shoes only go in one way to support the right brake hardware,so it should be quite difficult to get them wrong.One of the shoes should have and extra pin in it for the retracting spring and such.
carquest has a $8 package of all brake hardware (springs pins clips and such).FYI
keba is offline   Reply With Quote
Old 07-05-2007, 08:21 PM   #7 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
The shoes are the same size.
The friction material on the shoes should be different lengths.
The rear shoe should have more [longer] material.
It does matter if you put them on backwards, which IIRC is possible.
They will look alot alike, but shouldn't be identical.
And for the record you're better off getting aftermarket parts from somewhere like NAPA vs somewhere like autocrap or advanced.....
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Rear Drum Brake Q Damemorder Archived Corolla threads 6 09-20-2005 09:47 PM
painting rear drum boyet Camry & Solara Lounge 11 09-02-2005 10:25 AM
how do you change rear break light plastic nofear4189 Camry & Solara Lounge 6 12-29-2004 06:43 PM
gen 4 camry le rear drum adjustment goretro77 3rd & 4th Generation (1992–1996 & 1997–2001) 2 04-09-2004 01:35 PM
best brake pads front and rear and shoes for gen3? henry bui 3rd & 4th Generation (1992–1996 & 1997–2001) 2 05-14-2002 11:16 AM
