Someplace in the vicinity of the distributor, there should be a white wire with a red stripe.
With the ignition switch in the run position .... not start, just run, can you say that the W-R wire is hot ... it has 12 volts? Do you have a voltmeter or test light. Just scrape a little piece of insulation off if you don't see a bare terminal connection, and stick the + meter lead on the wire, and place the - meter lead on a clean, oil-free, paint-free piece of chassis or engine block. Be sure the meter is set to read volts .... maybe the 20 volt scale.
... The reason I ask this question is because there is a 10 amp start fuse that may have blown, and is the problem.
What do you think?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
