Originally Posted by etc
As usual, the Haynes manual is wrong about several things, even about such simple things.
You do not have to unbolt the bolt where the brake hose goes to.
From Haynes: "the center arrow points to the brake fitting bolt, which SHOULDN'T be unscrewed unless the caliper is being completely removed."
It says to squeeze the brake pads before you remove the caliper, I did it after.
The reason for doing it before you remove the caliper is so you can use a large C-clamp. If you do it after then a special piston compressor tool is needed - unless you use channel locks, which can be a pain. I prefer to use the piston compressor tool.
Also, it recommends unscrewing the master cylinder cap, I have never heard of anyone else suggest that.
If you squeeze brake fluid back into the master cylinder there is a possibility that you can over pressure the plastic reservoir and crack it. Safe policy is to loosen the cap.
Anyway, question -- I found one of my caliper bolts (Whatever they are called) frozen.
I think you mean the caliper slide pins, name used in Haynes.
I beat on it with a hammer and it moved. Is it dead?
Well, if you read the Haynes Manual, which does not recommend beating it with a hammer, you would have seen that it does recommend these pins be removed, cleaned, and lubricated. It is also recommended that you clean and lubricate the pin bores in the caliper as well. No it's not dead, but it could bind and cause uneven and premature wear on the pads.
The Haynes Manual is not the "Bible", and it does make mistakes, but not as many as people would make if they followed the manual.
