Weird Transmission Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2007, 02:58 PM   #1 (permalink)
View ajs3r9's Photo Gallery
3rd Generation Weird Transmission Problems
My car is a 92' camry with 5s-fe 113,xxx miles
I have had a lingering transmission problem for the past few months and last night it got worse. It happens on the 1 to 2 up shifts and it feels like a lack of power in second gear.
The car stays at 2200 rpms and feels bogged down, the engine rmps stays the same even if you put the pedel to the floor. The thing that worries me which happened last night was the O/D light on the dash has started flahsing when the problem arises. The car then feels bogged down for the rest of the time you drive it until its turned off and it seems to reset.
I read in the repair manual when the light flashes its the shift solenoids or the speed sensors. Does any one have experiece with this problem and could share any info, Please???
ajs3r9 is offline   Reply With Quote
Old 07-06-2007, 04:45 PM   #2 (permalink)
Just curious .... have you ever, or recently, changed the transmission fluid?
Old 07-06-2007, 05:21 PM   #3 (permalink)
Checked Oil
I'm pretty sure it was changed when i bought it. 10,xxx miles ago. The fluid is red and comes up to the hot measurement on the dipstick.
Old 07-08-2007, 07:51 PM   #4 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
Take it to Autozone, they will hook up the checker and it will tell you what's wrong. Looks like the tranny is taking a dump, but good luck!
mandyfig is offline   Reply With Quote
Old 07-09-2007, 12:16 AM   #5 (permalink)
3rd Generation Please Help!!
I've driven the car multiple times now and knoticed that the problem doesn't happen if driving the car gently. It only happens or so it seems to happen when accelerating fast in first when the car has to upshift at 4000 rpm. Shift Solenoid?? Has anyone ever had problems with one of these and could share? I'm in desperate need of any info. Thanks
Old 07-09-2007, 11:15 AM   #6 (permalink)
Missing My Camry...
Celeste's Avatar
View Celeste's Photo Gallery
I had the same problem, felt ok on local roads but got worse on the highway, by this time it was bogging hard. My fluid was still red but my mechanic said doesnt matter my transmission was shot and I had to get it rebuilt.
Celeste is offline   Reply With Quote
Old 07-09-2007, 12:08 PM   #7 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
Pull the pan. (Don't move the magnets, or note their positions.) Remove the shift solenoids noting which one has a black wire and which one is white, and test them with an air nozzle set at less than 60 PSI. Press the nozzle in the end opening and put 12 volts to the solenoid. (I hooked negative to the case and then touched pos to the wire.) The air should come out the smaller round holes. Once they are clicking freely and without hesitation each time you connect the 12 volts you can reinstall and refill with fresh fluid. I used a new gasket and mesh filter. Worked for me!
Dave's is offline   Reply With Quote
Old 07-14-2007, 10:36 PM   #8 (permalink)
3rd Generation Thanks
Thanks guys for the responses, i am going to borrow my friends compressor in the next week and test the solenoids out. Hopefully this will fix the problem and i can have smooth power again.
4cyl transmission problems Komete 3rd & 4th Generation (1992–1996 & 1997–2001) 9 03-11-2007 09:00 PM
How does the glass breakage sensor work? newbie212 Camry & Solara Lounge 5 01-03-2006 08:49 AM
91 supra transmission problems... shaunbert88 Supra Forum 0 10-19-2004 05:34 PM
