Quick Question about SRI - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2007, 11:40 AM   #1 (permalink)
digitalscars's Avatar
View digitalscars's Photo Gallery
4th Generation Quick Question about SRI
I just installed a Weapon R, SRI. my only problem is how to bolt it down, i have it set up now, so that it stays up and rests where the airbox was but usually after some driving it slips out of the bracet i have up against it and falls down some.
Any suggestions to make it extra strong, or some other way to hold it in place?
thanks
digitalscars is offline   Reply With Quote
Old 07-07-2007, 11:51 AM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
it shouldve come with a bracket i think ... is it the Dragon or the Secret Weapon?
4cyl or V6?
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 07-07-2007, 12:09 PM   #3 (permalink)
it did, but how is it supposed to connect, secret weapon. it came with two bracets
Old 07-07-2007, 12:27 PM   #4 (permalink)
Venom_5's Avatar
i think the brackets bolt onto the intake along the sides [should be a place for a nut] ... and then they probably go straight down to the engine bay walls somewhere
u might have to make holes for them, but idk for sure - i havent seen the Secret Weapon in person yet
Old 07-07-2007, 02:16 PM   #5 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
Just to let you the bracket is bendable. Didn't bother to read the install paper but I just use one of the holes where one of bolts was holding the bottom of the stock airbox and then put it between the coupler and clamp that holds the filter and then tighten it down and it doesn't move at all.
Not sure if that's way to do it but I guess it's up to you which hole you use I guess. Just to tell you I took off the whole stock airbox I didn't leave the bottom part on without taking it off I couldn't use the hole I used to put the bracket on.
felonyr301 is offline   Reply With Quote
Old 07-07-2007, 03:42 PM   #6 (permalink)
thanks, im going to do that. didnt think of doing that, and i removed the bottom of mine too.
Old 07-07-2007, 03:52 PM   #7 (permalink)
felonyr301's Avatar
The bendable bracket at one end has like three bends that side is what you put between the clamp and coupler and tighten it down and the other side just bend it yourself to bolt it down.
Old 07-07-2007, 05:55 PM   #8 (permalink)
Venom_5's Avatar
one of u guys take pictures when ur done
maybe i can do the same for my Dragon intake when it gets here <July 11th>
quick question leppercon_man Celica Forum 3 03-20-2007 10:32 AM
Quick Question! OneMnk 2nd Generation (2005+) 26 09-12-2006 05:42 PM
just a quick question paradizecityz 3rd & 4th Generation (1992–1996 & 1997–2001) 6 08-11-2006 11:53 AM
Quick CF hood question Ukrainian102 Archived Corolla threads 18 10-09-2004 11:27 AM
