noobie question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2007, 01:54 PM   #1 (permalink)
View exodiaus's Photo Gallery
3rd Generation noobie question
Hi guys, I have a 96 4 cyl 5sfe that just have the wheels changed. I change from stock 195/70-14 to 215/60-15. My question is that do i have to do an alignment after the change? THanks
exodiaus is offline   Reply With Quote
Old 07-07-2007, 02:20 PM   #2 (permalink)
View louie1086's Photo Gallery
nah. u only need the do alignment when u do something withe the suspension.
louie1086 is offline   Reply With Quote
Old 07-07-2007, 02:20 PM   #3 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
The speedometer is a little off you know. You should of used the 205/60/15 setup but it's not too far off with the setup you have. I don't think so it's usually when you get new suspension on the car but not sure about new wheels only.
felonyr301 is offline   Reply With Quote
Old 07-07-2007, 02:35 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
u shouldnt need an alignment because of switching the tires. however, a wider footprint will make any alignment issures more noticable. if u havnt gotten one in a while, say 30K miles, then it couldnt hurt.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 07-07-2007, 02:38 PM   #5 (permalink)
thanks guys
Old 07-07-2007, 02:59 PM   #6 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
If the wheels are aftermarket, you may also want to get hub-centric rings. When the stock wheels are on, the weight of the car rests on the hub of the wheel, and the lugs hold the wheel on, but with after market wheels the hub on the wheel is larger so the weight of the car is resting on the lugs (bad). Hub centric rings fill in the space between the hub on the car and the hub on the wheel so that the weight can rest on the hub an not the lugs. I got mine from a local speed shop for $10.
95PimpingCamry is offline   Reply With Quote
Old 07-07-2007, 03:50 PM   #7 (permalink)
felonyr301's Avatar
That depends on the wheel but usually it's bigger than the toyota's hub which I think is 60.1 or something like that.
Old 07-07-2007, 05:31 PM   #8 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $906827
iTrader Score: 59 reviews
I'd like to see what that size tire looks like on ur Gen 3.5...got pics??
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 07-07-2007, 06:18 PM   #9 (permalink)
View AJRK's Photo Gallery
I thought a 205/65/15 was the right "upsize" for 14" Camrys. Did the V6 Camry not come with 205/65/15's on it?
AJRK is offline   Reply With Quote
Old 07-07-2007, 07:15 PM   #10 (permalink)
View Novice_cardude's Photo Gallery
As for the alignment, as bigbird said if you haven't had it checked in a while, get 'er checked out.
It's a PITA for me as I work in a shop that has alignment programs (I only get a fraction of the pay for a free alignment than for a paid one), but if you have a 1-year, 3-year or lifetime program somewhere it's good to get it checked out every 6 months/6k miles, even if it's not pulling. Like I say, it's a pain for techs like me, but as much as I hate doing nothing but free alignments for a good part of the day, it is good preventative maintenance, especially if you have expensive tires.
Novice_cardude is offline   Reply With Quote
Old 07-07-2007, 07:37 PM   #11 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Yes, but the overall diameter is larger on the 205/65-15 compare to the 195/70-14 on your car. When you get bigger wheels, you generally try to keep the diameter as close as possible to what the car was equipped with.
2007 Camry 2.4L 5M
Old 07-07-2007, 07:43 PM   #12 (permalink)
i understand that, but wouldn't the V6 and I4 cars be the same, or would their speedo's be calibrated differently?
Old 07-07-2007, 07:49 PM   #13 (permalink)
The tire diameters are different, so I hazard guess that the speedometers are calibrated differently also.
2007 Camry 2.4L 5M
Old 07-07-2007, 07:51 PM   #14 (permalink)
Thanks for the info. I'll be buying some 205/60/15's in the fall!
Old 07-07-2007, 08:23 PM   #15 (permalink)
felonyr301's Avatar
It will have little less sidewall and more of the fender gap will be showing if you go with 205/60/15 since you probably got used to 215/60/15 but it's really not noticeable I wouldn't go crazy spending money on replacing just the tire size.
2007 Camry Sound System Question mw817 5th & 6th Generation (2002-2006 & 2007-2011) 36 12-27-2006 07:33 AM
Sub/Amp question Elizle Audio, Video, and Security - Tech 5 07-13-2006 10:42 AM
2007 Camry Question skippy126 5th & 6th Generation (2002-2006 & 2007-2011) 5 05-24-2006 07:47 PM
general transmission question, 2nd, 4th and reverse do not engage!! afyouthbrigade Camry & Solara Lounge 1 09-29-2005 06:58 PM
noobie wheel question FritoHead228 2nd Generation (2005+) 5 06-13-2005 03:05 AM
