ebrake/ foot brake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2007, 02:07 PM   #1 (permalink)
Lone star
blackhawk's Avatar
View blackhawk's Photo Gallery
3rd Generation ebrake/ foot brake
ok here i go a couple of day a go i was driving whrni notice my emergency bake came on... what now !!! i sed i stoped and pull the release lever and it did not go away any way i drove home turn the car off then on and it went away but now it on and not going off i tried to see if it was the switch but it seem like i need to do more than just pull the lower dash offf and stuff is their a fuse attached to this thing or is my 94 coupe gettin old
I HAVE NO IDEA HOW THIS WORKS
blackhawk is offline   Reply With Quote
Old 07-07-2007, 02:21 PM   #2 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Do you mean the emergency brake light is comes on the dash, or that the e-brake is actually engaged? Seems impossible that the e-brake would pull itself up when your driving...
geoff5093 is offline   Reply With Quote
Old 07-07-2007, 02:23 PM   #3 (permalink)
View louie1086's Photo Gallery
dude, first of all, theres something called punctuation marks. learn how to use them. second, check to see if any of the wires are torn. also check to see if there is anything wrong with your rear brakes.
louie1086 is offline   Reply With Quote
Old 07-07-2007, 02:25 PM   #4 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
You are low on brake fluid. I have this problem right now, its leaking from a 'splitter' behind the gas tank. Good luck.
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 07-07-2007, 02:30 PM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
it may also be a bad brake sensor, it went bad on my old car and even when disengaged the brake light was on, after each time i turned off the car it would reset but would happen again when i moved the ebrake again.. if ur brake fluid level is ok then thats prolly ur problem.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 07-07-2007, 02:35 PM   #6 (permalink)
Lone star
blackhawk's Avatar
thanks alot my brake master cylender went recently and i was about to get it replaced when i saw tht the fluid was below the limit an needed to be filled and ill make more sense next time thamks once againg and yes i do mean the emergency brake light is comes on the dash
Old 07-08-2007, 12:10 PM   #7 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
Like they said, its probably low brake fluid, top it off. My car did that and my friend's Nissan NX1600 did that too.
EvoFire is offline   Reply With Quote
Old 07-08-2007, 03:26 PM   #8 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Dude, there's something called capitals and apostrophes. Learn how to use them.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 07-08-2007, 04:23 PM   #9 (permalink)
I HAS BOOST!!!
bigbird's Avatar
what are yall, english teachers ...who the hell cares?
R.I.P.
Car Domain:
Old 07-08-2007, 04:51 PM   #10 (permalink)
Supraman
View 94_Toyo_Cam's Photo Gallery
A hose is probably leaking. With it parked and running, pump it a few times and take a look underneath to see any fluid on the ground.
94_Toyo_Cam is offline   Reply With Quote
Old 07-08-2007, 10:57 PM   #11 (permalink)
Lone star
blackhawk's Avatar
Yow it's was low brake fluid thanks alot TN family .... aww man i spelled a lot as one wordlol
Old 07-08-2007, 11:11 PM   #12 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
usually it's just because the pads are getting low
if there is fluid on the ground, the brakes would be noticeably bad and the car would barely stop....all it takes is one small leak to do that....
HaHa
94 Camry brake warning light eaglemtn 3rd & 4th Generation (1992–1996 & 1997–2001) 25 05-04-2012 11:57 AM
DAM U KSPORT & Your Big Brake Kit... trninhds 3rd & 4th Generation (1992–1996 & 1997–2001) 4 04-09-2007 02:44 PM
3rd brake light fuse popping gameguru1360 Archived Corolla threads 4 03-15-2007 03:21 PM
STRANGE Camry Brake Problem, Plz help!!! Tarzan Camry & Solara Lounge 15 03-18-2006 02:28 AM
Brake Questions Aaagogo Celica Forum 7 03-28-2005 10:22 AM
