Check Engine Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2007, 08:44 PM   #1 (permalink)
View ryane75's Photo Gallery
Check Engine Light
My check engine light came on in my 1998 Toyota Camry 4 cylinder last weekend. I thought it was maybe the gas cap so I tightened it and I drove it and the light still didn't go out. I unhooked the battery and the light stayed off for an hour today while I was driving and it came on again. I took the car to Autozone and it had a code of P0441 which stands for EVAP (Evaporative Emission System) small leak/no flow condition. It says the possible causes are:
1. Defective or loose fuel cap.
2. EVAP canister or hose cracked-not connected.
3. Purge or vent solenoid defective.
4. Vacuum leak at engine.
I replaced the fuel cap because it was the easiet, but the light is still on. Do I need to disconnect the battery again or reset the check engine light or is it something else ?
Thanks
ryane75 is offline   Reply With Quote
Old 07-07-2007, 08:51 PM   #2 (permalink)
Lone star
blackhawk's Avatar
View blackhawk's Photo Gallery
i would . by you disconnecting the battery i will allow the ecu to reset. the same happen to me when i canged from the stock filter to a short ram and i was bugging out . the i just disconnect the battey and allow it to chill for a couple of minutes then it was fine .i know it was a little off topic but hope it helped
I HAVE NO IDEA HOW THIS WORKS
blackhawk is offline   Reply With Quote
Corolla 2002 P1349 trouble code? check engine light. g.b. Archived Corolla threads 6 10-01-2009 01:52 AM
check engine light Islandtrix 1st Generation (2003-2008) 17 03-05-2009 01:02 AM
Locking gas cap and check engine light on Tacos paco 2nd Generation (2005+) 36 06-06-2008 10:00 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 11:52 AM
