I Need Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2007, 01:28 AM   #1 (permalink)
toyota = cool
tacomonkey69's Avatar
View tacomonkey69's Photo Gallery
4th Generation I Need Help!
So the lights on my speedometer are not working (yes I checked the dimmer switch ). All of the signal, hight beams, check engine and so on lights. The lights on the a/c and rear window defroster buttons still work but not the lights on the on the 3 air control knobs and the lights around them. I’ve checked the fuse and it's been blown. First i thought "hey it's an old fuse so I’ll just replace it”, well the replacement fuse blew. So what could be the possible problems and solutions? I really need to know because when I drive at night I don't know how fast I’m going.
oh yeah and i have a 97 CE V6 5spd and my radio still works if that helps.
tacomonkey69 is offline   Reply With Quote
Old 07-08-2007, 02:18 AM   #2 (permalink)
Is the 5 amp IGN fuse the one that has blown? Which fuse exactly?
When you put a new fuse in, do you see the "charge" light on the instrument panel glow briefly?
Thinking it might be a short within the rheostat (dimmer switch), but need more information first.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 07-08-2007, 02:02 PM   #3 (permalink)
toyota = cool
it's the 7.5 amp panel fuse. i changed it during day time so i couldn't tell if glowed briefly
Old 07-08-2007, 03:00 PM   #4 (permalink)
It could be a problem then with the dimmer switch .... shorted internally or something. Still kind of guessing here .... need to see if the dimmer pins are shorted out. Is it possible to remove the dimmer switch from the dash, without being a major project? Do you have an ohmeter or a voltmeter to test the pins on the dimmer switch? ... Basically, need to know if there is a short, or zero resistance, between the 'green' wire and the 'white with black stripe' wire on the dimmer switch.
Electric problem! Please help!! 1987SR5 Pre-88 Toyota Pickup/Hilux 2 12-02-2005 09:58 AM
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 10:27 AM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
