power steering fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2007, 03:10 PM   #1 (permalink)
View Libre's Photo Gallery
So I drive a 1994 Toyota Camry 1MZFE. I saw that the power steering fluid was quite low, so I got some power steering fluid and filled 'er up. But my dad just told me that you are supposed to use transmission fluid instead of actual power steering fluid. Was this a big mistake I made that will harm the engine? Or just a harmless one that can be easily remedied?
Thanks.
Libre is offline   Reply With Quote
Old 07-08-2007, 03:59 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Yes, the power steering system uses ATF. It says so on the cap IIRC.
I don't know what harm it would do but probably nothing good will come of it. You can try flushing everything out and replacing all the fluid.
2007 Camry 2.4L 5M
Old 07-08-2007, 04:43 PM   #3 (permalink)
View marc780's Photo Gallery
It probably wont harm anything. We have hydraulic lifts at work and the guys who service them tell me you can use either hydraulic fluid (for the lifts, not for cars of course) or ATF, and can mix if you have to.
After you fix the leak, you can just siphon out the fluid with a turkey baster, top up, run the engine a minute, siphon again etc. Do this about 4 or 5 times and it should be fine. A little bit of power steering fluid left behind wont hurt anything.
Old 07-08-2007, 10:38 PM   #4 (permalink)
Yeah, that's pretty much exactly what I was planning on do. I guess I will read the fine print on the caps from now on.
Old 07-09-2007, 06:49 PM   #5 (permalink)
So something horrible just happened to the car when my brother was driving it. He couldn't get it above 30mph and it stalls and it sounds horrible. The transmission fluid looks really bad so it could be a tranny problem. Then again, that tranny has 234xxx miles on it so its about time it goes. The bad news, a new tranny would be more than the car is worth!
I just hope the problem isn't related to my power steering fluid mix-up.
Old 07-09-2007, 07:23 PM   #6 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
If you think a new tranny is expensive, try buying a new car.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 07-10-2007, 10:25 AM   #7 (permalink)
I think it's an engine problem and not a tranny problem now. Sounds really bad too, how ironic is it that the day after I register for TN my car's engine blows.
power steering fluid colour!? wtf 95 COROLLA Archived Corolla threads 14 06-02-2009 10:18 AM
2001 tacoma power steering fluid type bigsteve 1st Generation (1995.5–2004) 2 07-05-2007 09:08 PM
Need help with power steering leak kauz 1st & 2nd Generation (1983–1986 & 1987-1991) 9 06-05-2007 08:34 AM
Power Steering Fluid Question ericcyl Camry & Solara Lounge 12 10-15-2006 09:53 AM
Power steering noise after flushing/changing the steering fluid Camry 2001 Mark22 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-26-2005 12:34 PM
