Rear brake shoes replacement... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2007, 04:25 PM   #1 (permalink)
View Syke Fu's Photo Gallery
Hey guys, I have a 1995 Camry LE I4 and I’m absolutely stumped on how to replace these rear brake shoes. I with I had some pics to post, but I don't so I’ll try and be a descriptive as possible. I've got the drum off the car along with both shoes. Now, I’m trying to get the actual parking break lever off the rear shoe. It has 1 clip on top that holds the auto adjusting lever, which I have taken off np.
Now....
I got the 2nd clip that holds down parking brake lever, and I’ve also gotten the lever itself off. Now.... The little piece that it sits on is like pressed into the shoe itself. How do I get that piece out of the shoe??
Any help is greatly appreciated. I'm now in day 2 and hour 7 of this brake job.
Syke Fu is offline   Reply With Quote
Old 07-08-2007, 04:39 PM   #2 (permalink)
View marc780's Photo Gallery
I'm not sure what you are talking about. If you are talking about the pivot pin, maybe its end has mushroomed a little and you have to drive it out with a punch?
Old 07-08-2007, 04:49 PM   #3 (permalink)
Yeah, i think thats it! So are they pressed into the shoe or can i just hammer it out? Thanks!
Old 07-09-2007, 06:54 PM   #4 (permalink)
Unco's Avatar
View Unco's Photo Gallery
hammer it out with a pin punch. be gentle.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 07-09-2007, 07:17 PM   #5 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Do you mean where the parking brake lever is held on to the rear shoe by the "c-washer"?
Those c-washers are a one use item. You need to use a screw driver to separate the two arms to pull the pin out. You need new c-washers so that you can squeeze the arms together that hold the brake lever to the shoe. I have never needed to a hammer to remove this after the c-washer has been removed.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 07-10-2007, 11:05 PM   #6 (permalink)
Thanks! I'll give it another go this weekend.
Old 07-11-2007, 02:14 AM   #7 (permalink)
Unco's Avatar
Originally Posted by Stillrunning
[/color]
that's right, i guess i just assumed that he'd already taken the c-washer out.
Old 07-11-2007, 09:47 AM   #8 (permalink)
View keba's Photo Gallery
oreillys has a complete brake hardware kit for 8 bucks. all new springs c-washers ,circlips,pivot pins ,cups etc.
The center pins on my older shoes were terribly rusted which is why i decided to do the entire set anyway.
Getting the springs on and off was a big b****.and the one time tool was like 15 bucks.Fortunately I found this hand tool called a scratch-awl(3$) which worked perfect for those tight little spaces.
keba is offline   Reply With Quote
Whiteline; Superpro and Dobinson Group Sale ...PART II raptorracing Supporting Vendor Sales 93 05-02-2007 05:02 AM
Removing rear brake drums NickR Tercel, Paseo, Starlet, and Sera Forum 5 08-22-2006 07:47 PM
best brake pads front and rear and shoes for gen3? henry bui 3rd & 4th Generation (1992–1996 & 1997–2001) 2 05-14-2002 11:16 AM
