1. If the clock is keeping time, then it would seem to have power. The resetting switches might be worn and not making good contact when you press them. Sometimes excess humidity will cause such a problem.
You might try some electrical contact cleaner on the push switches, but you would probably have to remove the clock and access the circuit board for this procedure to be effective. Best fix might be to obtain a replacement clock from a salvage yard. .... If you could remove the clock, you might be able to locate the relevant push button solder pads and wire your own switches, and install them at a convenient location. That would depend on the construction of the clock circuit board.
2. The problem with the left front door courtesy light might be the mechanical door light switch. ... Not sure if it is on the door, or on the main chassis door panel. If you can access this switch, look for a red wire with a green stripe. If you take a jumper wire and ground the R-G wire to the chassis, the light should go on if the switch was not working properly.
3. The rear left window doesn't work with either the main window switch or the remote switch? It could be that there is something that is internally defective within the main power window switch module. I would disconnect each connector going to that main switch module, spray liberally with electrical contact cleaner spray, and firmly plug back in. Has anythin been spilled into the window switch module lately .... soda, coffee, syrup?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
