timing belt question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-09-2007, 10:35 AM   #1 (permalink)
View 1996camry's Photo Gallery
HI,
is good pratice to keep the timebelt a little loose when replace a new timebelt?
1996camry is offline   Reply With Quote
Old 07-09-2007, 11:09 AM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
not a good idea. it will slap around (dont ask me how i know this).
Old 07-09-2007, 11:15 AM   #3 (permalink)
View Yanpapa's Photo Gallery
I completly agree with ghettosled. I have to go back and redo everything because my belt was loose.
97 Camry LE 4 cyl. 5S-FE 160K miles
10 Corolla LE 15K miles
Yanpapa is offline   Reply With Quote
Old 07-09-2007, 09:25 PM   #4 (permalink)
what is too tight and too loose?
Old 07-09-2007, 09:36 PM   #5 (permalink)
Unco's Avatar
View Unco's Photo Gallery
what do you mean? have you actually read the workshop manual? there is a procedure involved. it usually involves turning the crankshaft to get the correct tension. have a look at the manuals posted in the camry general forum and look for the procedure involved for your type of engine, which you didn't give any details about btw.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 07-11-2007, 07:35 AM   #6 (permalink)
ghettosled's Avatar
there is a spring that puts tension on the belt. i found that spring alone doesnt give enough tension and my belt slapped. i used a pry bar to give some more tension. once, i gave it too much tension and it gave the motor like an electronic sound at idle. (i think that sound was because of the strain on the oil pump from the belt being too tight.)
Timing Belt Question grh1107 3rd & 4th Generation (1992–1996 & 1997–2001) 1 04-11-2007 12:35 AM
93 Celica Timing Belt + Distributor Is the Shop telling the truth? jamesbrogdon Celica Forum 16 05-03-2006 05:44 PM
I Help You With Timing Belt Celler Tercel, Paseo, Starlet, and Sera Forum 4 04-02-2006 09:08 PM
question about timing belt... T3vzGfeF Camry & Solara Lounge 1 09-20-2004 06:23 AM
