Alternator removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2007, 03:04 PM   #1 (permalink)
View Mitsouko1's Photo Gallery
Question Alternator removal
My alt is on the verge of extinction so I decided to try to replace it on my own. Im far from a mechanic but got the adjusting and pivit bolts removed and was ready to remove the alternator until I noticed it wouldnt budge, there seems to be some kind of sleeve (lack of a better word, hollow ring) going thru one side of the mounting hole keeping the alternator in place at the pivit point. Im stumped on how to get this thing removed any help would be appriciated.
Mitsouko1 is offline   Reply With Quote
Old 07-10-2007, 03:36 PM   #2 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
if i remember, there are only two bolts holding it on
you removed those right?
try tapping it with a rubber hammer and some wd40
WhiteRabbit is offline   Reply With Quote
Old 07-10-2007, 03:39 PM   #3 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Yep theres 2 bolts. The adjusting bolt and theres a bigger bolt. I think its a 14mm
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 07-10-2007, 04:22 PM   #4 (permalink)
The alternator on my 98 was also a tight fit. Just as an experiment, you might try getting a can of spray starting fluid and spraying this only on the alternator piece that goes between the long bolt holes. The idea is to thermally shrink that particular piece of metal on the alternator .... enough that it will slide out.
.... Try not to get any of this spray on the mounting bracket, only on the alternator piece.
... Not sure how much it will take ... just enough to cool the middle piece down some.
... Don't light any matches with a bunch of starting ether around the engine bay.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 07-10-2007, 05:34 PM   #5 (permalink)
thx for the replies ill give it another shot and try beating it out
Old 07-10-2007, 06:05 PM   #6 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
dude take it from me...its eay...once you remove the two blots that hold it in, use a wrech, or screwdriver to push it out from its hole...because its a tight ass fit!!!!!!Also the plug on top of the alternator its a screw take off the cover and your good to go
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
