ok here ya go ....
remember, all the colors reflect the same thing throughout all the pictures
-- first, the blue circles indicate the clips - there are 4 of them where the bottom half of the air box meets the top half, im sure you know that ... they are in all four corners
-- then the 2 orange circles indicate 2 clamps that have phillips-head screws [i think size 2 or 3 if you have a tool set with #s] ... unscrew both of them if you want this to be super easy, otherwise you just have to unscrew the one closest to the airbox to barely pull the intake hose off the airbox
--next, the yellow circle indicates that clip i was talking about ... ill attach a closeup that shows the wire its holding, you just have to slide that wire forward out of the clip so it doesnt hold the box cover down
then u should be able to pull the box straight up once the intake hose & that wire are detached
if you have any more questions, just ask!
best of luck
