Any qualified mechanic or shop should have a pressure pump and gauge that will attach to your radiator ..... where the cap goes. The idea is to pump up the air pressure until it reaches a level equivalent to that produced by normal engine operation. You watch the gauge for 5 or 10 minutes, and observe whether the gauge needle stays steady, or falls. .... 100% accurate as far as telling you there is a problem with the cooling system. .... If the leak is external to the engine block, you can usually see the coolant coming out some place.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
