Screeching from A/C? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-12-2007, 09:31 PM   #1 (permalink)
'94 Toyota Camry V6 Owner
View iarenick's Photo Gallery
Holy crap, as I was driving down to pep boys for some brake fluid, my car made a loud screeching noise right when i pushed the A/C button. Is there any explanation for this?
iarenick is offline   Reply With Quote
Old 07-12-2007, 10:49 PM   #2 (permalink)
View unkit's Photo Gallery
I had the same thing happen to me in my 94 Camry, The compressor on my AC died. Mechanic said he could just replace the clutch, which would fix the problem, and would be a lot cheaper, but would prolly stuff up again.
unkit is offline   Reply With Quote
Old 07-13-2007, 10:55 AM   #3 (permalink)
3rd Generation
Replacing the clutch? This most likely means I need a new compressor doesnt it?
Also the A/C doesnt work very well. It wont turn very cold when the weather out is hot.
Old 07-13-2007, 10:59 AM   #4 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
yup, clutch is bad ... might as well replace the whole a/c compressor if youre gonna be down there ... but its pricey
i have the same problem
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 07-13-2007, 04:09 PM   #5 (permalink)
5S-FU
View Sniperdude's Photo Gallery
Same here...
Sniperdude is offline   Reply With Quote
Old 07-13-2007, 04:16 PM   #6 (permalink)
View Total Chaos's Photo Gallery
Yeah, it sounds like you either have a bad clutch or even a seized compressor. I would just bite the bullet and get both the compressor and the clutch.
Total Chaos is offline   Reply With Quote
Old 07-13-2007, 05:05 PM   #7 (permalink)
Gameroom cash: $303055
Before jumping to expensive conclusions, check the tension on the A/C belt. It may be too loose. You may very well need a new clutch and/or compressor, but check the cheap thing out first.
Mike
Old 07-13-2007, 05:42 PM   #8 (permalink)
Thanks, Mike. I totally had a brain fart there. I completely forgot about the tensioner.
92 Celica ST - After 1 year of not driving A/C does not work Guitarlp Celica Forum 5 07-05-2007 03:46 PM
A/C always on; bad dash switch? bad relay? How to Test? ladd2 Camry & Solara Lounge 8 05-01-2007 06:11 PM
1998 Avalon A/C Issues ignoreme 1st Generation (1995-1999) 2 04-11-2007 10:47 AM
A/C Not blowing Cold Air garrand3006 Archived Corolla threads 4 08-09-2006 04:08 PM
