brake issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2007, 11:04 AM   #1 (permalink)
View slstone s2k kid's Photo Gallery
brake issue
hey guys, i just replaced the pads and rotors on my 97 camry, but i seem to have run into a problem. After the complete installation i took the car for a little test drive and noticed that the brake pedal was very sensative, it would need to be pushed down all the way for the vehicle to stop at a low speed. what could be the problem? I really need some feedback. THANKS GUYS
slstone s2k kid is offline   Reply With Quote
Old 07-13-2007, 11:31 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I'm not sure I understand this, "noticed that the brake pedal was very sensative, it would need to be pushed down all the way"
If you pressed the caliper pistons back in order to install the new pads then the brake pedal will need to be pumped a few times to bring the new pads up against the rotors, That should reduce the brake pedal travel. Are you still having this problem? You also should have had to withdraw some brake fluid from the reservoir as the new pads would have forced excess fluid back into it.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 07-13-2007, 12:40 PM   #3 (permalink)
i even bled the calipers, and pumped brake fluid back through the lines but still no luck.
Old 07-13-2007, 04:04 PM   #4 (permalink)
View keithy's Photo Gallery
have you checked the brake fluid level? spongy brakes normally is caused by air in brake line(s). Try bleeding all brakes again and look closely at the brake fluid level. You may have a leaking brake lines......... just my 2 cents.
keithy is offline   Reply With Quote
Old 07-13-2007, 06:31 PM   #5 (permalink)
How did you bleed? Use a helper to pump the pedal while you opened and closed the bleeder screws?
Old 07-13-2007, 08:07 PM   #6 (permalink)
View toyomoho's Photo Gallery
Are the pads or pistons hung up in the calipers? Have someone pump the pedal while you watch the pads.
Old 07-13-2007, 11:34 PM   #7 (permalink)
well i'll give this a shot first thing in the morning, thanks for all the coments.
IIM - Ksport Procomp Big Brake Kits - 8 PISTON!! ImageInMotion Supporting Vendor Sales 8 07-08-2008 12:21 AM
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
gen2 brake light stays on... help... please.. busted_ride 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-24-2004 04:56 AM
Soft brake pedal when car is on--booseter issue? Lumberg Camry & Solara Lounge 6 09-16-2004 04:55 PM
