help! master window controls not working. thanks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2007, 07:31 PM   #1 (permalink)
WALKING AND TRAVELING SUX
View umeshr85's Photo Gallery
HELP. i messed with the kill switch or bypass switch on my alarm, i replaced it. anyway. my alarm stopped beeping and it doesnt make noise anymore at all, but still closes and uncloses the doors. the controls on the driver's door no longer work, the door lock and unlock button works, but the 4 window buttons dont work. the windows do however go up and down when using the windows controls on each door. thanks. whats wrong with my car? think its a relay? or just replace the whole master controls? THANKS.
PARTS FOR SALE: http://www.toyotanation.com/forum/sh...d.php?t=302022
I install headunits,amps, subs,speakers in NYC. Private message me.
umeshr85 is offline   Reply With Quote
Old 07-13-2007, 07:45 PM   #2 (permalink)
View toyomoho's Photo Gallery
The door lock circuit is separate from the window circuit. The windows receive power from the drivers console and a separate power wire to each window. In this manor they can be operated independently of the drivers console. If the windows work with each door switch, check the drivers console.
Old 07-13-2007, 08:52 PM   #3 (permalink)
it was the drivers console aka the master controls. its messed up.
here is how to troubleshoot it. i checked the wires in the black plastic loom between the door and the fender part of the car by the a pillar. there are wires that are joined and black taped but they seem fine. and i could not see a flasher behind the ashtray, maybe there is one, but i'd have to take off the plastic around the center console, so i disconnected the master window controls from the drivers side door and what do you know, the alarm was working fine again. so the controls are defective, the unit. i'll pick one up somewhere. do you think that i caused it to stop working yesterday when i changed the alarm bypass switch by the kickpanel? i also pushed the controls down a little, by hand with force, cuz it was sticking up a bit. thanks.
Old 07-19-2007, 03:17 PM   #4 (permalink)
i bought a used main switch. still the windows dont work. the door lock works, just like on the old unit. what could it be?
anyone ever change their main switch and it still didnt work? then what did you try?
Old 07-19-2007, 05:43 PM   #5 (permalink)
PROBLEM SOLVED. THANKS FOR THE HELP.
i'm going to return the master control i ordered. i dont need it. the wires between the door and the body of the car are in black loom of plastic, there was a broken wire inside there. so i joined it and everything is back to normal. goodluck.
Need help with 99 Camry window repair! aznarkitekt 3rd & 4th Generation (1992–1996 & 1997–2001) 4 06-13-2011 03:35 AM
WTB - 94 Camry master power window switch Robar Car parts for trade or wanted parts 1 06-18-2007 08:23 PM
2000 Camry power window not working shahid11 3rd & 4th Generation (1992–1996 & 1997–2001) 5 01-05-2007 08:18 AM
Window Tint Noise tjg184 2nd Generation (2005+) 8 09-06-2006 12:36 PM
