Why (do I hear) rubbing? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2007, 10:16 PM   #1 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation Why (do I hear) rubbing?
Okay, since I put 16X7 rims (35 offset) on my camry, i tend to hear a rubbing sound from my passenger side when I turn either right or left. When i took it to an alignment shop, they only thing they noticed that needed to be replaced was the driver side outer tie rod end, and since it wasn't me who brought the car in (it was my gf with my credit card ) she had it replaced then had the alignment done. They did not notice the rubbing sound. I even took it back once and they still couldn't hear it. I took it to another indepenent shop that does suspension work and for some reason they could not reproduce it either. Now, I know I'm not crazy because I've had other people in the car with me and they've heard it. I'm running 205/60/r16 tires on all corners, which from what I'm reading isn't a problem otherwise. I've turned the wheel to the max and tried to feel where it could be rubbing and don't seem to see or feel anything. I'm probably going to put my 14" wheels back on this weekend just to see if it still makes the noise, but in the meantime, is there anything else I can check?
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 07-13-2007, 11:09 PM   #2 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
is it a distinct rubber on metal/plastic contact?
could be something else: cv boots, rotors, etc. but those are easily identified usually...
WhiteRabbit is offline   Reply With Quote
Old 07-13-2007, 11:33 PM   #3 (permalink)
Quasi-Evil Monkey
renmike's Avatar
3rd Generation
Yeah, I had it up on jackstands one day and had a friend turn the wheel with it in drive and would give it a little gas while turning, like going through a parking complex, and it wouldn't make any noise anywhere. For some reason, to me it sounds like the wheel/tire is rubbing on the plastic fenderwell. and just for clarificaiton, how could the rotor be making the rubbing noise unless the caliper was sticking, or is that what you meant?
Old 07-13-2007, 11:35 PM   #4 (permalink)
TN's furry friend
^yea, rotor on caliper, but then that would be more of a high pitch squeak
Old 07-14-2007, 04:14 AM   #5 (permalink)
View 94CoupeV6's Photo Gallery
My car makes a rubbing noise ever since I installed my springs and I found out it's just the strut mount is shot.
94CoupeV6 is offline   Reply With Quote
Old 07-14-2007, 03:31 PM   #6 (permalink)
Quasi-Evil Monkey
renmike's Avatar
3rd Generation
Well, I just had new struts and mounts installed on all 4 corners.
I'm probably just going to put my 14's back on today and see what I hear (or don't hear). If it's still there, which I suspect it will be, I'll take a closer look when i'm on vacation later this week.
lifted and rubbing with 285 70 17 JoeHe 2nd Generation (2005+) 5 04-02-2006 05:40 PM
rubbing and wheel issues/gearing q's 96camry4dr 2nd Generation (2005+) 0 03-04-2006 02:12 PM
How much can I lower without rubbing?!?!? MattSWE Camry & Solara Lounge 5 01-22-2006 06:59 PM
Rubbing on uppercontroll arm w/3inch lift trdspeedwayblue 2nd Generation (2005+) 11 12-27-2005 06:17 PM
Rubbing Sound on Turns flex-appeal Hardcore Tech and Competition 2 05-12-2005 07:59 AM
