Check engine light on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2007, 03:21 PM   #1 (permalink)
View myminx'scamry's Photo Gallery
Dear Friends,
This weekend I flushed the radiator and dropped the tranny and cleaned the screen and added new tranny fluid. Now the check engine light is on. I rechecked the fluid levels and everything is fine. Did I miss something here? What should be my next step in figuring what is causing the light to come on? After I did the services it was fine for a day before the light came on. This is a 1994 with the 3.0L V6. Thanks for your help!
PS Just a note: I bought a new tranny strainer and gasket at Murrays Discount Auto Parts and either did NOT fit! I put the old one back in after I cleaned it. Just a warning to you all!
myminx'scamry is offline   Reply With Quote
Old 07-15-2007, 08:12 PM   #2 (permalink)
'94 V6 Auto
View Kevin89AllTrac's Photo Gallery
Take the car to Autozone or Checkers or wherever and have them read the CEL code. They'll do it for free. Write down the CEL code and diagnose the problem using the 1MZ-FE repair manual PDF in the FAQ section of this forum. Maybe you knocked a sensor harness connector loose when you were doing the work.
Kevin89AllTrac is offline   Reply With Quote
Old 07-15-2007, 11:22 PM   #3 (permalink)
View newbie212's Photo Gallery
Autozone cant read his check engine light.. His car has OBD1.. If the car was 96 or newer they could read the check engine light..
newbie212 is offline   Reply With Quote
Old 07-16-2007, 09:24 AM   #4 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
He has the V6, so a 94+ V6 is OBDII.
When you bring it to AutoZone or other auto parts store, they will say they cant because it's a '94, but dont listen to them, the V6 models ARE OBDII.
geoff5093 is offline   Reply With Quote
Corolla 2002 P1349 trouble code? check engine light. g.b. Archived Corolla threads 6 10-01-2009 02:52 AM
check engine light Islandtrix 1st Generation (2003-2008) 17 03-05-2009 02:02 AM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 10:50 PM
Is the 07 camry tranny a POS ?? Eyekutr 5th & 6th Generation (2002-2006 & 2007-2011) 97 01-22-2007 12:20 PM
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 12:52 PM
