Slow sticky windows - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2007, 01:23 PM   #1 (permalink)
View iceminion's Photo Gallery
Slow sticky windows
Hello, I am new here, and I have searched the site for my question already.
my 92 camry has window problems, the pass side window is really slow, going up and down.
the stock motor/regulator eventually took a crap, so I replaced it with a new unit.
the window is still slow, and I can feel the new unit grinding and stressing.
It feels like the guides are sticking, I lubed them up and it helped a little.
would replacing the window tracks help?
Thanks.
iceminion is offline   Reply With Quote
Old 07-16-2007, 01:28 PM   #2 (permalink)
340,000 miles+......
sk8ersublime's Avatar
View sk8ersublime's Photo Gallery
yea i have a 95 and the windows go up so slow...i wish i knew why they are so slow
http://www.cardomain.com/ride/2915998
340,000+
sk8ersublime is offline   Reply With Quote
Old 07-16-2007, 01:44 PM   #3 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
same here
must be a volt drop or something
is yours an i4 or v6, ive noticed it in my friends i4 too. but my sister's v6 has smooth windows
WhiteRabbit is offline   Reply With Quote
Old 07-16-2007, 01:55 PM   #4 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Sometimes I have found that spraying WD40 or like down the tracks/guides cleans them up and lubricates them enough to lower friction and increase speed.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 07-16-2007, 02:07 PM   #5 (permalink)
i have a v6 and its slow...:-\
340,000+
Old 07-16-2007, 03:27 PM   #6 (permalink)
I have ruled out low voltage. The failure of the stock motor/relay was due to the excess stresses on the cables/pullies, causing eventual failure of the pullies.....my stock motor still works fine, just the cable is ruined.
does anyone know of a way to refresh/replace the window slides?
Old 07-16-2007, 10:54 PM   #7 (permalink)
OK! I HAVE THE ANSWER, LISTEN UP!!!
Symptom: window
there is a rubber seal that starts down by the door speaker, travels up over the window and back down all the way down to about where the red warning light is (on the door)
Remove the glass (easy) 2x 10mm bolts
pull the rubber seal out, if it is filty clean it, most likely it will be clean and supple, mine is from an abused 92 and it was not hardened at all.
get a flashlight, inspect the metal track where the rubber gasket was just pulled from
IF THE TRACK IS PINCHED CLOSED EVEN A LITTLE BIT, IT WILL MAKE YOUR WINDOWS HARD TO RAISE/LOWER
Mine was pinched by the mirror, someone must have hit something with the mirror and it flexed in and bent the track.
I just stuck a screw driver in the track and bent it back into shape, which worked for me.
you can replace the tracks, I'll bet that toyota doesnt charge too much for them, totally worth it in my opinion.
I hope this helped.
Old 07-17-2007, 09:58 PM   #8 (permalink)
The only okie in here
View OSUpeterson09's Photo Gallery
BS. I know for the rubber guide tracks on my 99 toyota camry, toyota wants either 80 or 180 for each. Im pretty sure it was 180 each. I have to live with windows that are slow and that close crooked so air comes through them because toyota fucks you on them.
'99 Camry I4 - INJEN SRI - Clear Corners - Euro tails - New Muffler - Gauge color mod - More coming soon!
I'm looking for any oklahoma ppl with camrys on here. Let me know.
OSUpeterson09 is offline   Reply With Quote
Old 07-23-2007, 01:27 PM   #9 (permalink)
View thisisntjoew's Photo Gallery
3rd Generation
The problem with mine tured out to be the master switch. The contacts corrode over the years and create a AMPERAGE drop not a voltage drop to the motors this is what can cause slowing and failure of the windows. I have attempted to take apart the switch and repair it but it is nearly impossible to reassemble correctly. My advise is to buy a new one. Getting a used one usually has enough corrosion to cause the same problem.
3rd Gen/5s-fe/Camry
thisisntjoew is offline   Reply With Quote
Windows Vista Pricing - From Amazon SolaraTRD Off Topic 3 08-30-2006 10:27 AM
windows master switch fungke Camry & Solara Lounge 9 11-09-2005 07:28 PM
GEN 5 Owners: Air Conditioning On or Windows Down ... Which Consumes More Gas??? LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 14 06-20-2005 11:31 PM
detailing the windows Xevuhtess77 General Discussion 8 09-20-2004 11:05 PM
Windows - Delayed Write Failed EasyE Off Topic 0 07-30-2002 05:44 PM
