Originally Posted by Mike Gerber
...You will see 2 or 4 screws that hold the radio cage to the dash...
On my '95 LE they were 10 mm screws with slots for an phillip's screwdriver - but they were so tight I started to strip a couple so I just used a 10 mm socket.
Anyway, I've put in my share of radios over the years and changing my Camry's radio was the easiest one I've done. That piece of trim pops right off, remove the four bolts, and the radio is out. When putting in the new radio you won't be using the new radio's installation cage nor the new radio's trim ring. And assuming you have a pocket under your stock radio already, you won't be using a kit.
It's as easy as taking candy from a baby.
