93 Camry Le wont start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2007, 09:41 AM   #1 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
3rd Generation 93 Camry Le wont start
My cousin 93 wagon died on him a couple of days ago, i went to go see the car and thought i could help but no success. The car is receiving power inside the car, but when you try turning it on it seems as if it isnt getting any spark to the engine. We tired giving it gas while turning it on but nothing happned. All fuses are working i believe it may be the starter but im not sure. If you guys need more info i'll let you know, i'll also take a video of how it sounds
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 07-17-2007, 09:44 AM   #2 (permalink)
toyocam99's Avatar
Gameroom cash: $118835
View toyocam99's Photo Gallery
If you hear a clicking sound when trying to turn it over it may be the starter, other than that I don't know.
toyocam99 is offline   Reply With Quote
Old 07-17-2007, 10:55 AM   #3 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
What does it do? Does it crank and crank and crank? I cant tell in your post what its doing.
1992 Lexus ES 300 5 Speed -My baby- 111K - Slightly modded 3VZ-FE - Denso Iridium plugs/Vitek Wires - KYB Struts & Mounts - Whiteline RSB
2000 Toyota Solara SLE V6 Auto 3100 miles on the clock (Summer ride)
92ES5sp is offline   Reply With Quote
Old 07-17-2007, 11:20 AM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
yeah, you have to describe a little more of what youre hearing.
Old 07-17-2007, 11:26 AM   #5 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
It's very possible to have enough battery to operate the interior but not enough to crank the engine. Have you tried a different battery or jumping it?
Dave's is offline   Reply With Quote
Old 07-17-2007, 12:47 PM   #6 (permalink)
Creeps228's Avatar
yea it does keep cranking and nothing happens, i was thinking of giving it a jumpstart but it sounds like the battery is good, because is does crank but no go. It just keeps cranking over and over, but nothing really happens...he had told that while looking for parking the started to loose power until it eventually turned off. When we first turned it on[today], it seemed to start but instantly died...Tomorrow if its possible i'll post up a video of how it sounds.
MR2: 7A-GE
Old 07-17-2007, 01:23 PM   #7 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
We don't need to know how it sounds, just that it cranks but does not start. You need to determine if the plugs are getting spark. Pull a plug and ground out the threaded portion on the engine. Have someone turn the engine over for a couple of cranks and see if you are getting a good blue spark.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 07-17-2007, 01:24 PM   #8 (permalink)
denysimo's Avatar
View denysimo's Photo Gallery
Hi! Maybe I can help...If the starter turns over/ cranks but engine does not start, it might be due to a faulty starter coil. I had this problem before and replaced this $15 part and it worked!
denysimo is offline   Reply With Quote
Old 07-17-2007, 01:25 PM   #9 (permalink)
Creeps228's Avatar
ok, i'll try that out tomorrow but for now, i just need to keep getting suggestions
MR2: 7A-GE
Old 07-17-2007, 03:08 PM   #10 (permalink)
Jeep Survivor
jrcrum's Avatar
View jrcrum's Photo Gallery
I agree with Stillrunning -- check for spark first. Either pull a plug and check it like he said, or pull one of the wires and stick a screwdriver up into the connector of the wire, hold onto the metal handle of the screwdriver, and rest the base of your hand on the aluminum valve cover, and have someone crank the engine. If it makes you cuss, then you've got a spark, and you can go on to check for fuel.
jrcrum is offline   Reply With Quote
Old 07-17-2007, 04:14 PM   #11 (permalink)
92ES5sp's Avatar
Sounds to me that if it lost power and died, it lost fuel pressure. What engine is in the Camry? If the cranking sound weird, like there is no compression, the timing belt may have snapped. But yeah check spark and check fuel. (And fuses)
Old 07-17-2007, 06:50 PM   #12 (permalink)
92ES5sp has a point. The Timing Belt may be broken. You could also pull the distributor cap and see if the rotor turns. No turning, probably TB. If rotor turns then check spark. Don't go by the shock you may get, you'll want to see a good strong blue one.
Old 07-17-2007, 07:30 PM   #13 (permalink)
Jeep Survivor
jrcrum's Avatar
Reading back through the symptoms, I'm thinking possibly the fuel pump is bad, or the fuel filter is stopped up. Or, uhh.. it ran out of gas?
Or it could be the timing belt, as others mentioned above. I would still check for spark first. You have to approach this by a process of elimination. If you get a spark, the timing belt isn't broken completely, but it could still have slipped.
Old 07-17-2007, 11:07 PM   #14 (permalink)
Creeps228's Avatar
thanks for the suggestions, it does have gas, about 1/4 of tank, im going to try to see if i can get a spark if that doesn't happen, i'll try a jumpstart then i'll go into detail after what happened...thanks for the help...everyone...hopefully this isn't major problem for him
MR2: 7A-GE
Old 07-19-2007, 04:55 AM   #15 (permalink)
5SFE
Lord_Anarchy's Avatar
View Lord_Anarchy's Photo Gallery
alternator?
Lord_Anarchy is offline   Reply With Quote
Camry 93 V6 LE engine swap , maybe for a lexus engine ?? sbaksh 3rd & 4th Generation (1992–1996 & 1997–2001) 4 01-29-2008 12:01 AM
color of inside door handle for 93 camry le hyperaesthetic 3rd & 4th Generation (1992–1996 & 1997–2001) 7 06-14-2007 12:45 PM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
question for 93 camry le front speaker poiu7890 3rd & 4th Generation (1992–1996 & 1997–2001) 1 09-16-2003 05:42 AM
