My cam needs an overhaul (Not for 56k) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2007, 08:21 PM   #1 (permalink)
asscarracer's Avatar
View asscarracer's Photo Gallery
So I took some pictures of the camry today. Its accumulated some minor to major problems lately.
To start off, battery has started to corrode. Its about five years old. I dont know if cleaning it is even worth it or if I should just replace the thing.
The coolant reservoir clip busted. It's held for now. So I might just leave it.
The mirror is commiting harry carrie. Not sure if there is an easy patch for this one.
The lock cylinder won't accept the master key.
And last but not least the windshield crack has widened.
In 2006 I had the cap, rotor, brakes, brake rotors, brake hardware and shoes, sparks, plug wires, motor mount, flexpipe and radiator replaced.
I think I’ve already paid for a few ASE certs
1993 Camry LE w/ 104xxx mi
Python Remote Start/Entry, Low-Beam Silverstars, Ceramic Pads, Double Tipped Platinum Plugs
asscarracer is offline   Reply With Quote
Old 07-17-2007, 08:47 PM   #2 (permalink)
View louie1086's Photo Gallery
dude, these are minor issues, except the windshield, but alot of your parts can be replaced by going to the junkyard.
louie1086 is offline   Reply With Quote
Old 07-17-2007, 08:49 PM   #3 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
my battery was corroded so bad when i moved that the terminals fell off ... just replace it, cleaning is FUTILE!
as for the mirror, get it from a junkyard and paint it .... it shouldnt be expensive for such a small part
for the window, youre gonna havta get it filled with resin ASAP unless its too big - then u better replace the rear window before it spreads
as for the lock, well .... i dont use my trunk keyhole anyways, so i would just say screw it!
and i have a new reservoir and clip, they were cheap @ the stealership a year ago
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 07-17-2007, 09:16 PM   #4 (permalink)
on full afterburner
Gameroom cash: $1338897
I had the same problem with my trunk lock.
Spray some WD40 on the outside and inside of the lock, remove the trunk carpet and spray the mechanism there. Jiggle it until it loosens up.
Old 07-17-2007, 09:20 PM   #5 (permalink)
The green corrosion seen on the positive battery terminal is characteristic of a defective voltage regulator .... a part which is internal to the alternator, if I recall. Either get a new alternator or take it to a starter/alternator shop and get it rebuilt. If you have any doubts about this, take the car to an automotive shop that is qualified to diagnose such a problem. .... No point in just cleaning the terminals ..... You might also need a new battery .... 5 years is about all you can expect.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 07-17-2007, 10:42 PM   #6 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
Originally Posted by dc_98_cam
The green corrosion seen on the positive battery terminal is charactistic of a defective voltage regulator
That is not true
1992 Lexus ES 300 5 Speed -My baby- 111K - Slightly modded 3VZ-FE - Denso Iridium plugs/Vitek Wires - KYB Struts & Mounts - Whiteline RSB
2000 Toyota Solara SLE V6 Auto 3100 miles on the clock (Summer ride)
92ES5sp is offline   Reply With Quote
Old 07-17-2007, 10:57 PM   #7 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
that green crap is oxidized copper caused by the ultra slow corrosion of the copper components close to and in the battery terminals and in the battery itself. its possible that there is a regulator problem but ud start to see problems with charge and starting if it was anything to worry about, though 5 years sounds like time for a change in ur battery. thoes are all little problems, not an overhual. but the little things do add up, i add them every day
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 07-17-2007, 11:06 PM   #8 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Yep just minor stuff. I don't mess with windshields tho. lol.
Better get that battery done first before it gets you stuck.
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 07-17-2007, 11:08 PM   #9 (permalink)
92ES5sp's Avatar
Yeah these arent a big deal. The regulator has fail safe circuits that take over in the event of a regulator failure. Otherwise charging voltage could top out at 250 V plus and fry every piece of electronics in the car. Thats just from a lack of cleaning. I cant tell how bad the corrosion is because the cap is blocking the view, but you may need a new + cable end.
Old 07-18-2007, 04:28 PM   #10 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
Dude, spend 10 minutes with a wire brush and you'll clean the corrosion all off, why did you even let if get that bad?
MIC0417 is offline   Reply With Quote
Old 07-18-2007, 05:15 PM   #11 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $906827
iTrader Score: 59 reviews
All ez fixes!!..the windshield is gonna cost ya a few bucks!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
1MZ Cam marks won't align dgspencer Camry & Solara Lounge 5 03-15-2006 08:32 PM
85 Camry Cam Bearings Question Netwriter 1st & 2nd Generation (1983–1986 & 1987-1991) 7 10-14-2005 08:46 AM
Part 2: Advancing cam timing allblackalltrac Hardcore Tech and Competition 0 04-16-2004 05:27 PM
Every one say hello to Euro Cam II (warning 19 pics) EuroCamz Camry & Solara Lounge 39 04-01-2004 05:03 PM
