1996 camry Le making noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2007, 10:54 PM   #1 (permalink)
View 1996camry's Photo Gallery
I have a question... my 1996 Camry Toyota Le 4 cylinder 5sfe engine... when i turn around 360 degrees, i heard a clicking sound....and then if i return back to 180 degree (on thd road) then the noise go away... only happen when turn 360 degrees (like go around the circle)... two weeks, i got passenssar axial replaced and bearing replaced... the noise was there before i replaced axial and bearing... Do you guys have any suggestion what can be? this noise only happen when you turn 360 degrees.and if you go straight like 180 degrees...there isn't any noise at all... the noise like clicking and clicking (sound like a meter rub against a rubber)....
has anyone has the same problem i have? suggestion is away appreciated...
thanks...
1996camry is offline   Reply With Quote
Old 07-17-2007, 11:14 PM   #2 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
I cant tell what youre trying to say BUT could be either CV joints or a u-joint in the steering column.
1992 Lexus ES 300 5 Speed -My baby- 111K - Slightly modded 3VZ-FE - Denso Iridium plugs/Vitek Wires - KYB Struts & Mounts - Whiteline RSB
2000 Toyota Solara SLE V6 Auto 3100 miles on the clock (Summer ride)
92ES5sp is offline   Reply With Quote
Old 07-18-2007, 06:47 AM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
check the driver's side CV joint. the clicking noise when the car is making a turn is 9 times out of 10 a bad CV joint. on the passenger side, was the whole axle replaced or was just the CV boot replaced?
Old 07-18-2007, 07:26 AM   #4 (permalink)
it was CV boot replaced (boot that connect to passenssar wheel)...orginal my wheel shaking when i jacked it up..and hold the front passenssar 's wheel...the wheel shaking...that is the only reason i replaced CV boot...... the noise sound come from the passenssar side...and clicking when turn 360 to the right to left ...is the a way you can check CV joint? can u do test drive to verify...i am thinking to hold a tape recorder to record while i turn the 360 degrees....the sound cliking and clicking..then i return to 180 degrees..the sound go away.....this happen only when turn 360 degree...if i turn 90 degrees..i don't heard the noise...only i turn a sharp turn..i heard the noise..
Old 07-18-2007, 10:47 AM   #5 (permalink)
correction make previous msg....it was not CV boot... i replaced the whole passensser axle....any ideal what i can be the noise..i appreciate suggestion....
Old 07-18-2007, 10:51 AM   #6 (permalink)
5S-FU
View Sniperdude's Photo Gallery
You also might be hitting the wheel locks if you turn too tight... it's to prevent the wheel from turning too far out.
Sniperdude is offline   Reply With Quote
Old 07-18-2007, 12:10 PM   #7 (permalink)
View J708's Photo Gallery
I had the exact same problem and when I replaced my CV joints the noise went away. So yeah its the CV joint 99.99999%.
Camry 1996 2.2L - 121,000+ miles
J708 is offline   Reply With Quote
Old 07-18-2007, 02:18 PM   #8 (permalink)
can CV joint test under driving condition?
'97 Camry LE - Famous rattling noise bluechipbmw 3rd & 4th Generation (1992–1996 & 1997–2001) 9 04-13-2007 01:56 PM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 06:27 AM
92-96 Camry LE V6 suspension- supposed to be firmer than 4-cylinder? 93 Camry LE V6 3rd & 4th Generation (1992–1996 & 1997–2001) 6 09-20-2003 02:33 PM
1996 LE Camry 2.2L HELP! StealthAssasin 3rd & 4th Generation (1992–1996 & 1997–2001) 7 02-25-2003 01:22 PM
88 Camry making horrible metal to metal engine noise Danielson 1st & 2nd Generation (1983–1986 & 1987-1991) 2 10-05-2001 02:07 PM
