That looks about the same as the 98 5s-fe. Try using a combination wrench ... 14 mm? from the lower side access panel. There should be just enough room to get to those two bolts. If you can just get a wrench to grip on the bolt head, you can devise some kind of cheater or lever to assist on the end of that wrench. I don't recall using a ratchet here ... not sure if it will fit.
.... Or do I understand the problem? Are you sure you have the wrench on the bolts?
.... If you can in fact get a wrench on the bolts, then go to a GM car dealer and buy a spray can of
"Rust Penetrant and Inhibitor" part# 1052627
Spray liberally, and let set for a while .... maybe repeat. You should get some results, as this is very effective.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
