valve cover gasket, drain oil first? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-18-2007, 11:45 AM   #1 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
do i need to drain the engine oil first before removing the valve cover? haynes manual didnt mention anything about it...
thx
WhiteRabbit is offline   Reply With Quote
Old 07-18-2007, 11:47 AM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
nope. in fact, in my opinon after you finish and put the valve cover back on, i would turn the engine for a couple of minutes to flush anything that was jarred loose into the oil pan then change the oil.
Old 07-18-2007, 11:49 AM   #3 (permalink)
TN's furry friend
cool thx
fast reply O_O
Old 07-18-2007, 12:32 PM   #4 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
haha, i know all about this after my lil gasket incident...
no draining necessary, the oil level is below the gasket - while youre down there, check for sludge [take some pics!] and there might be some melted plastic or whatnot from the old gasket, so get them out .... everything should be pretty easy to spot if your engine is as clean as mine was
if you need any help, just ask - i just had to do this like 3x in the last month
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 07-18-2007, 12:39 PM   #5 (permalink)
TN's furry friend
since i cant read my haynes right now, what size socket to i need for the spark plug bolts
Old 07-18-2007, 12:51 PM   #6 (permalink)
Venom_5's Avatar
30mm ... its a huge b*tch!
lol ... got it from O'Reilly's [AutoZone and Advance were out of stock] for like $10
im better than a haynes manual! woot!
Old 07-18-2007, 12:54 PM   #7 (permalink)
ghettosled's Avatar
just an FYI - the axle nuts are also 30mm so its worth while buying the socket.
Old 07-18-2007, 12:55 PM   #8 (permalink)
TN's furry friend
cool thx, i dont think i have a 30mm in my socket set...damn
ill have to pick one up then
Old 07-18-2007, 01:32 PM   #9 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Pickup a 6 point not a 12 point. Axle nut quite thin and difficult to hold on to and a 6 point socket will not round the flats as easily.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 07-18-2007, 02:42 PM   #10 (permalink)
Venom_5's Avatar
all i use is 6-point ... so yeah, listen to stillrunning
it was easy as crap to use, too
the only problem is my TQ wrench minimum torque is 50 ft-lbs, and i was told that they nuts go back on with 33 ... so i just guesstimated ... make sure those shits are on strong tho, or ur gonna leak out 2 qts like i did!
Men, Women and Oil Changes... BLUEMEANIE Off Topic 15 09-26-2007 09:42 AM
toyota settles law suit on engine geling/sludge teriboberry 1st Generation (1995-1999) 26 01-14-2007 09:51 AM
gen 2 v6 valve cover gasket install smkdwnn 1st & 2nd Generation (1983–1986 & 1987-1991) 3 08-22-2006 01:14 PM
okay to tighten spark plug tubes (valve cover is off)? 97&02camryleI4 Camry & Solara Lounge 4 07-10-2006 02:12 AM
Valve cover gasket replacement White Buffalo Pre-88 Toyota Pickup/Hilux 1 01-02-2006 06:37 PM
