AC/ air vent troubles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-18-2007, 03:46 PM   #1 (permalink)
View camry93's Photo Gallery
3rd Generation AC/ air vent troubles
My 1993 Camry V6LE has a problem with the air vents that I hope someone could give some advice on.
With the AC on it blows cold on the PS center vent and vent by PS door but the DS and DS center vent blows partial cold air.
Is there a damper that is not switching all the way, if so where should I look. I have the Haynes manual but it does not show much other than testing the switches.
Thanks
camry93 is offline   Reply With Quote
Old 07-18-2007, 10:45 PM   #2 (permalink)
View toyomoho's Photo Gallery
See if you can download the climate control info form the Toyota service manual at the link below:
http://oregonstate.edu/~tongt/camry
Old 07-19-2007, 06:28 AM   #3 (permalink)
I looked at the online manual and it show that the two center vents are fed from the same duct line. I noticed that this manual is for the North American made Camry and mine is Japan made.
Does anyone know if the vent ducting is different NA vs. Japan made?
There must be some reason I am getting much cooler air from the passenger side center vent than the drivers side center vent?
Old 07-19-2007, 08:39 AM   #4 (permalink)
View Mjakaz95LE's Photo Gallery
wow mine does the exact same thing and was just about to post this!my buddy's 01 accord had this prob and took to dealer, I guess there was some door or flap that wasn't workin. so not sure if it may be something similar?surely someone knows about this because this is my 3rd camry that does it!
Mjakaz95LE is offline   Reply With Quote
2003 Camry Se Intake In Pic!! rgud 5th & 6th Generation (2002-2006 & 2007-2011) 72 04-25-2007 10:03 PM
Vent (air) selector 2000 camry kongkong 3rd & 4th Generation (1992–1996 & 1997–2001) 6 01-20-2006 04:42 PM
Stale Smell in AC Vent for 96 FalconDrgn 1st Generation (1995-1999) 11 07-22-2005 05:39 PM
Cabin air vent question MikeX 2nd Generation (2005+) 18 06-15-2005 03:12 PM
AC vent stuck on defrost? smoky723 Camry & Solara Lounge 0 12-13-2004 12:42 PM
