How 2 take off 93' interior door handle. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-18-2007, 04:02 PM   #1 (permalink)
"The" sleepy sleeper :(
View 2slo5sfe's Photo Gallery
I gave the wrong information last time.
I was explaining how to remove the door handle but, didn't realize that the one I'd been removing was missing a clip. Thus making the directions wrong.
So these insrtuctions are for someone who has not already cracked or broken their door handle.
It's easier with two hands. But I took the pictures myself, so that is why you wont see a second hand holding the screwdriver.
1. firstly you'll need a flat head screwdriver. The thinner the tip the better (not narrow across the head just the thickness of the blade.)
Insert the blade above the lock hinge.
2. Pry the housing up. (away from the handle while pulling back on the handle.) You may have to use a little force but deffinately not much.
3. Once you've got the top off the hinge, pry back the top as shown here don't pull too hard , just enough to stop the top from goiung back into place. Then insert the flathead below the hinge and pry the housing down away from the handle by pulling up.
4. Now slide the flat head over to the side of the handle shown below and try to shove it back you should only have to go in about an inch in total.
Here is a better view.
5. So you are holding the top housing out andpulling back on the handle all the way open now. Once the bottom is pryed down enough the housing should pop down and out towards you a little. This step will take a bit more force on the hand that is prying than the top did. DO NOt use excessive force though, as it will crack the hanle housing.
6. If you have done this right, your hand will allready be in the right place to pull the housing back and away.(as shown below) The housing will come right off.
7.While donig the above pull the handle back.
NOw you can see the bottom hinge clip and the slide clip on the back of the housing.
To put it back on just get it in place by reversing steps 6 & 7 and slowly inrease pressure untill it snaps into place. You may have to play with the handle a bit to get it to pop in. But it's a heck of a lot easier than taking that piece of crap out.
2SLO
I want rims!
2slo5sfe is offline   Reply With Quote
Old 07-18-2007, 04:21 PM   #2 (permalink)
Official TN user
Tuner571's Avatar
View Tuner571's Photo Gallery
Great DIY man, they should definitely sticky this.
95 Toyota Camry V6
http://www.cardomain.com/ride/2489322
Tuner571 is offline   Reply With Quote
Old 07-18-2007, 05:01 PM   #3 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $906827
iTrader Score: 59 reviews
For sure sticky this ...Put it in FAQ's
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 07-18-2007, 09:29 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
http://rayrayonline.bravehost.com/frontspeaker1.htm
someone already did.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
93 to 96 engine swapped distributorLess HAWAIITC Tercel, Paseo, Starlet, and Sera Forum 2 09-07-2006 01:31 PM
Clear 93 Tercel headlights CamryOwner98 Tercel, Paseo, Starlet, and Sera Forum 8 06-09-2006 05:15 AM
ADR Fuel rims fit my 91n/a w/ 93 brakes? mr2naturbo MR2 Forum 1 09-12-2005 06:14 PM
