Gear Lever - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-18-2007, 05:03 PM   #1 (permalink)
hav
View hav's Photo Gallery
4th Generation Gear Lever
i have a 99 V6 Auto with 115 K. Why does the gear lever feel tight sometimes, after the car is started and shifted to Reverse or Drive from the parking? Is there anything that can be done. I new cars I have noticed it is much smoother. I also had a flush done around 3 K miles ago
hav is offline   Reply With Quote
Old 07-18-2007, 09:07 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
that just sounds like a stiff lever. check the linkage to see if its binding anywhere.
try moving the shifter through the gears when the car is in the on position but not running. if it moves freely then it may be an actual tranny problem.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 07-18-2007, 10:18 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Do you use your parking brake or park on hills? If the car rolls after you put it in park, it will make it a bit harder to take it out of P.
2007 Camry 2.4L 5M
Old 07-19-2007, 07:07 AM   #4 (permalink)
hav
Yeah! I was parking in hills without the Parking Brake. Now I have started using it. It seems to have made a little difference. The gear othersise shifts pretty smooth apart from the starting shift. Do I have to do any major Tranny work or just keep going?
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
Tranny Oil Xlerator 1st Generation (1995.5–2004) 3 03-19-2007 05:02 PM
'05 Taco Speed/RPM charts Sonny 2nd Generation (2005+) 4 03-11-2007 01:08 PM
Gear Lever slightly tight shifting from P to RNDL jpbear Camry & Solara Lounge 4 06-13-2006 08:35 PM
Gear Shift Lever is Locked superdesi Camry & Solara Lounge 8 07-21-2003 09:15 PM
