Head Gasket Leak Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2007, 02:11 AM   #1 (permalink)
Toyota Camry Vienta CSi
View Aussie_Camry's Photo Gallery
I think my head gasket has an external leak, I have noticed recently a very small puddle of coolant from the front cylinder bank along the edge where the transmission, starter motor etc are. I have looked around and its not from a leaking pipe and I can quite clearly see its from the join between the iron block and the alloy head. I dont think there are any internal leakages as my exhuast doesnt have white smoke, the cars runs perfectly etc. My question, is there any way to fix this without major work? Or anyway to slow it down... as Im assuming the crack that exists is only going to get bigger, to a point where the coolant lost is to much (currently the coolant hasnt really needed to be filled up in the overflow although its maybe 2cm lower then usual... not huge yet)
Help appreciated
Aussie_Camry is offline   Reply With Quote
Old 07-19-2007, 06:10 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
From your description coolant does not seem to be getting into the cylinders. I would keep an eye on the oil to see if coolant is leaking into it. If it is only an external leak it may be just the head gasket. Why don't you take it into a shop and get them to pressure test the cooling system. When it is pressurized you may be able to see exactly where the leak is. Have you had recent work done to the engine? If this is just a weep leak then maybe re-torqueing the head may seal it. Have you over heated the engine recently?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Corolla/Prism Head Gasket wheredoesthisgo Archived Corolla threads 3 03-24-2007 10:39 AM
Doing the Head Gasket - 22RE BSDeality 89-95 Toyota Pickup/Hilux 15 02-23-2007 03:36 AM
head gasket leak... Camry LE 94 3rd & 4th Generation (1992–1996 & 1997–2001) 24 01-14-2007 09:17 AM
Machining challenges, or why the gasket fail Doctor J General Discussion 3 11-18-2006 02:30 AM
Head gasket theory needed peterng 89-95 Toyota Pickup/Hilux 4 01-15-2006 09:51 PM
