Brake light/Shifter interlock problem
Im going on a long distance trip with my 95 camry xle v6.
Once in a blue moon, actually ive only had it twice in like the past year, and it went away, i get this problem that doesnt activate the shifter interlock, allowing me to get out of gear, even if i push the brake pedal. the first time this happened, the taillight warning light wasnt on, but the 2nd time, it was on, and i had no brake lights nor could get it out of gear (without using the bypass button). I still had the regular tail lights when i turned on my headlights, just not stop lights when i pressed the brake pedal.
My question is this, are the two even related? is there another switch on the brake pedal (like other cars) that seperately runs the shift interlock? or do the stop lamps and shift interlock both work off the brake pedal switch. and if so, is that the only place they come together? cuz if so, then my problem should only be the brake switch getting stuck no?
