Ok, for posterity's sake, I'll leave the original post below... what was actually happening was some other high pressure leak blasting against the MAP sensor.
I'm still stuck changing that hose, I suppose.. Now I'm trying to figure out how to change that one.
=========== ORIGINAL (INCORRECT POST) BELOW ===================
I'll come back later with a picture, but I have a pretty major gas leak, by all appearances spewing from the MAP Sensor on the firewall, when the engine is running. The Gas Leak is a steady spray (about like squirting out glass cleaner on a spray setting), and like I said, it *looks* like it's coming from the MAP sensor.
Keep in mind, with that kind of gas leak you don't leave the engine running for long... Circumstances are I guess it drove about 50 miles like that at least... (nothing like driving along watching the needle actually move)
So... my questions are..
- Is it the MAP sensor? I thought that was Air going to the MAP Sensor..
- If it is the Map Sensor... It looks simple enough (but an expensive part) to change... am I wrong?
- What else might it be?
Thanks in Advance... (I love my Camry... although I'm a bit disappointed in it.. this makes THREE things that have gone wrong on it in 120K miles and 7 years!
