Speedometer runs too fast - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-22-2007, 09:01 PM   #1 (permalink)
View yelkenli's Photo Gallery
3rd Generation Speedometer runs too fast
My 94 Camry speedometer readout seems to indicate a higher speed than actual. At one time while stopped, the speedometer read 5 mph, and at another time 15 mph. While actually moving, maybe at 35 mph, the speedometer reads around 50 mph.
Any idea what might be the problem.
Also interested in the technology. Is this a magnetic pick-up or hall effect type sensor on a toothed gear, or some other technology.
Thanks
yelkenli is offline   Reply With Quote
Old 07-22-2007, 10:57 PM   #2 (permalink)
View toyomoho's Photo Gallery
The differential has a speed sensor installed on the top. The sensor appears to generate an alternating signal via a rotating magnetic ring (much like an alternator at four cycles per rev of its shaft). The signal goes to the instrument cluster where it is reshaped to a square wave and sent to the ECU.
Old 07-23-2007, 12:38 AM   #3 (permalink)
You might check the connection where the speed sensor plugs in .... near the differential, probably. Just disconnect .... spray with electrical contact cleaner, reassemble. Also, inspect the wires in the vicinity for any signs of frayed insulation, or anything unusual.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Wiring - Speedometer Sensor Arved 89-95 Toyota Pickup/Hilux 12 11-26-2011 08:27 PM
Yet another speedometer problem. ForGreatJustice Camry & Solara Lounge 13 01-03-2008 07:31 PM
1986 Toyota Celica GTS Speedometer hark659 Celica Forum 2 03-30-2005 02:50 PM
speedometer correction bfh4n Hardcore Tech and Competition 2 10-26-2003 12:39 AM
Speedometer Cable Snapped ?? Ferg Camry & Solara Lounge 1 08-02-2002 02:58 PM
