A Few Noob Lighting Questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2007, 01:52 AM   #1 (permalink)
View built2burn's Photo Gallery
4th Generation A Few Noob Lighting Questions
I have a 99 le camry and only basic knowledge on cars. I also work 3rd shift at a hotel so i have 5-6 hours per night of internet browsing.
I plan on lighting the dash cluster dome light and ignition light right now and i have a few questions. I have read all the dyi's that i could find and i've kind of gotten confused about some things, and i dont wanna order something that won't fit or work correctly.
For my dash cluster
1. Should i use incandescent or LED lights(which are brighter/last longer/whiter)?
2. Do i have to do anything else or do i just replace the lights(any other modding)?
3. On Superlumination.com there are so many bulbs that seem the same is there a difference between and what are better
4. is 194 the correct size?
Ignition
1. Can i take the cover from around the ignition or can i only take the cover from below the steering wheel(where the fuses are)
2. is 74 the correct size?
Dome Light
1. Again from Superlumination.com what would be prefered.
2. All i have to do is plug it in(no other modding), right?
3. is 3175 the correct size?
MISC questions
Will these clear corners fit w/o modding?
http://cgi.ebay.com/ebaymotors/1997-99-TOYOTA-CAMRY-EURO-CLEAR-CORNER-LIGHTS-W-BULBS_W0QQitemZ280133107406QQihZ018QQcategoryZ3370 8QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Same with these headlights and are these very bright/white?
http://market.autopartsfair.com/toyo...tem-10004.html
http://market.autopartsfair.com/toyo...tem-10003.html
Thanks for anyone that helps
built2burn is offline   Reply With Quote
Old 07-23-2007, 01:30 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
these links wont work, and the clears should fit fine.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 07-23-2007, 11:17 PM   #3 (permalink)
I'm Sorry I copied/pasted from something else
or should i just get some bulbs(i looked in the manual and it said H4 or something and i cant find any good bulb for that so would there be a way to easily mod a diff light into it?)
Old 07-23-2007, 11:31 PM   #4 (permalink)
'99 5 Speed 1mz
Stonegrave's Avatar
View Stonegrave's Photo Gallery
9003 and h4 are the same thing, which might help you find some better lights.
this site has alot of good lights.
if that link didnt work, then here it is again
http://www.automotivelightingusa.com...90ceb3abc25465
the dash lights are 194, and putting led lights into them will work. ive found that cheap ones from murrays or autozone have a deeper color, but dimmer. i dont remember what size the dome light is, but what i did was measure the OEM one and then just bought one the same length.
http://www.cardomain.com/ride/2173282
^Cardomain(last page has updated pics 8-24-11)
http://www.youtube.com/watch?v=nK4mf...el_video_title
^ghetto video of new exhaust, need to take one of it in action. It doesn't do it justice!!!
Stonegrave is offline   Reply With Quote
Old 07-23-2007, 11:36 PM   #5 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
i blew out my dome light, well actually i broke it and blew a fuse, but its 31mm long and 11mm wide...i do believe that it was 3175 since i went to autozone to find some white ones, which they didn't have so i ended up buying the license plate ones which are 2825 but if anything you should go to autozone and look at their lighting book
1999 TOYOTA Camry
High & low beam headlamp
9003/HB2
9003SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9003ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9003XV XtraVision Halogen - The Brighter Light
9003CB Cool Blue Halogen - The Whiter Light
Parking light
1157A
1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1157ALL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1157A
Rear turn signal
3156
3156LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
3157
3157LL Long Life Upgrade: Up to twice the life of the standard lamp
904
Stop light
3157
High mount stop light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
License plate
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
921
Front sidemarker
1157A
Rear sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Glove box
37
Dome light
DE3175
Step/Courtesy light
DE3021
DE3175
Trunk/Cargo area
194
Instrument-general
194
74
FYI...if your going to change the color of your HVAC unit the two blubs are 74
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 07-24-2007, 01:56 AM   #6 (permalink)
thanks for the help and i saw that list of bulbs on sylvania's website and it confused me with the H4/9003 but i got that straight.
and LED is bettter than incandecent for the 194s
I still would like to know if i should replace the bulb or headlight box or both
2007 Tacoma Questions from a Noob Volrus 2nd Generation (2005+) 38 02-24-2007 11:12 AM
Two noob questions. WhiteTrash2775 Solara 9 07-13-2005 07:22 AM
Exterior Lighting Questions RedPhoenix Camry & Solara Lounge 3 03-15-2005 03:24 PM
noob that knows nothing needs help w/ some questions grimlock MR2 Forum 2 08-23-2004 12:46 AM
