Do yourself a big favor and pick up a few of the cheap aluminum drain plug gaskets at the dealer. Install a fresh one when you close it up. Torque to 36 lbs/ft.
I'm not sure what this has to do with my question?
It's a 10mm hex or allen key. Get the kind that fits on a 3/8" or 1/2" drive ratchet. Those L shaped keys won't have enough leverage for you to take it off.
in actuality it would be best if you dropped the pan and replaced the filter/strainer, and check your magnets while in there.
__________________ Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD! Newest addition- 1987 300zx Turbo! what a blast!
Shit, that will work. So this is a 10mm allen wrench.
I'll just put a hammer on it to open. The reason why I want to open it is because I changed the transmssion fluid and filter and the fluid darkened a bit so I want to drain and refill with new fluid again. Hopefully it will lighten the fluid a bit.
well if your transmission fluid got dark after you changed it its due to the torque converter, theres a bunch of fluid in there...so its going to mix with the new fluid and the fluid is going to get darker
__________________ 99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd Camry:Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
