Help!!! Is my compressor gone? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2007, 06:32 PM   #1 (permalink)
View stanleyeye's Photo Gallery
4th Generation Help!!! Is my compressor gone?
Today, I was driving on the freeway and turned on the AC. I could heard the hiss, but I didn't pay attention to that. I turned if off after it ran for a while. When I turned it on again, the problem was still there. But suddenly, I felt a little jumping, and the A/C light began blinking, and there was some oil smell...
Then I tried several times. every time, when I turned on the AC, I could feel the load of engine increasing, ( the rpm higher), but only several seconds later, I could feel a jump, like something ( I guess it's the compressor) stop working (rpm jump a little then return to lower rpm which is around AC off), air becoming warm, and I could smell a little strange oil smell.
Does any one know what's wrong with my car? Is my compressor gone, or is the MC relay bad, if yes, how to test it?
Thanks a lot
Stan
stanleyeye is offline   Reply With Quote
Old 07-23-2007, 06:41 PM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
i dont think its the compressor because my compressor is shot and mine doesnt do that
your rpm's should go up when you turn ur a/c on <hence why a/c lowers mpg and hp> - but idk about all this jumpyness
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 07-23-2007, 06:51 PM   #3 (permalink)
Just now, I tested it again. When my wife turned it on, I kept watching the compressor, which started to run, then immediately stopped. Hopefully, the compressor is good.
Is it possibly bad magnetic clutch sensor, but gen4, I have never seen people complaining the sensor?
Old 07-23-2007, 06:58 PM   #4 (permalink)
Venom_5's Avatar
idk how the gen4 is setup, but i know our clutch itself dies with old age
but that wouldnt do any funky jumping, it would just make the air change cold to hot randomly
Old 07-23-2007, 07:07 PM   #5 (permalink)
If the compressor is broken, what would the symptom be? No response at all, when the AC on?
Thanks
Old 07-23-2007, 07:09 PM   #6 (permalink)
Venom_5's Avatar
pretty much .... and a grinding/whirring noise ... kinda makes the same noise as the engine but its louder
Old 07-23-2007, 07:13 PM   #7 (permalink)
View toyomoho's Photo Gallery
Might be smelling compressor oil, check to see if the system has a leak.
Old 07-23-2007, 08:45 PM   #8 (permalink)
just now, replaced the drive belt, but it doesn't work...
Old 07-23-2007, 08:51 PM   #9 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
Mine is acting funny too recently. I started it sometimes this winter like for window defrosting and randomly just so it runs sometimes for a quick moment and did exactly what you had. Start and stop. I thought well maybe because it's cold outside it doesn't want to run too much.
But now this summer my A/C is cold and everything, but the car is very sluggish and rpms don't always go up when I put it on. It whines pretty loudly too.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 07-23-2007, 09:10 PM   #10 (permalink)
Did you try to do anything to fix it?
Old 07-23-2007, 09:21 PM   #11 (permalink)
DIY : I believe
Maim Menu's Avatar
Well.....no. At least not yet since it's still cold and technically functionning and my A/C light never blinks.
With the blinking and oil smell of yours I'd take the car for a ride around the block and try to reproduce the problem, then pull up in the driveway and check for leaks.
If not a junkyard A/C compressor shouldn't cost much
Old 07-24-2007, 01:34 AM   #12 (permalink)
engineer in training
Gameroom cash: $145055
You need to have the system checked out, the compressor is oiled by gas in the ac lines and if it's low its the same as the compressor being low on oil. Have the system looked at by a good shop and check back in here for more advice.
Old 07-24-2007, 04:31 PM   #13 (permalink)
Yes, I will, but I don't know where should go...
Dealership: I really doubt they will check it step by step by following the manual instructions. Probably, they will just tell me to replace compressor, or even condensor...
Neighbor Autoshop: I checked the symptom online, and looks like the AC light blinking only on Toyota vehicles, I am a little worry if they are really familiar with this.
Old 07-24-2007, 07:29 PM   #14 (permalink)
Ask around about the shops in your area, someone is bound to know of a reputable one.
