MY00 CAMRY 4cl LE auto, how to add transmission fluid. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2007, 11:21 PM   #1 (permalink)
View pigpig's Photo Gallery
i noticed that my car is a little slugish, esp. when it's cold, i decided to check the transmission fluid, and found it was low.
when the car is hot, the reading on my dip stick is 1/3 inch lower than (hot Min)
my question is:
1. what kind of fluid?
2. how much do i need? i heard over-fill the tranny is bad.
3. how do it refill? through the dipstick pipe?
thanks
pigpig is offline   Reply With Quote
Old 07-23-2007, 11:48 PM   #2 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
You fill the transmission oil through the dip stick so i suggest you get a funnel
If your going to add transmission oil i sugguest you drop you pan and and drain the old fluid, put in new transmission fluid...it also depends on the mileage of your car...because i had bought three bottles of transmission fluid for cars over 75,000 miles i forgot the name...i only used two bottles plus a bottle of LUCUS transmission lubricant type of thing dont remember the name atm, but the car is running better than ever and i have a 1999 LE
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 07-24-2007, 12:03 AM   #3 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
never use fluid additives or lube, btw ... it can cause air pockets/bubbles and all sorts of problems
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 07-24-2007, 12:09 AM   #4 (permalink)
Creeps228's Avatar
well i added Lube on my trans. i've been running on ew fluid and lube for aout two weeks now and i havent had any problems, plus i replaced the fliter and the socket thing ( i dont for wat is called) OH the seal and right when i finished pouring in the lube ( did that first ) put in three bottles ( dont remeber how much i believe it was three ) started the car and went through each gear. Repeated going through the gears three times and then went out and took it for a spin...ran brand new
MR2: 7A-GE
Old 07-24-2007, 08:33 AM   #5 (permalink)
thx for suggestion.
i have 100K, i changed my filter (the pan) and fluid last year, so i guess i don't need to flush the whole thing again this year.
the question is: how much fluid do i need to if i am 1/4 inch down than the HOT MIN line?
Old 07-24-2007, 02:09 PM   #6 (permalink)
Creeps228's Avatar
the oil i had was Valvoline...its in a red bottle and it says its good from engine over 75K and its good for toyota, honda, ect transmissions....jus if you wanted to know
MR2: 7A-GE
Old 07-24-2007, 03:16 PM   #7 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
mobil 1 synthetic ATF ftw
WhiteRabbit is offline   Reply With Quote
1997 Camry Transmission Fluid Change Question cyman73 3rd & 4th Generation (1992–1996 & 1997–2001) 16 12-07-2011 08:10 PM
Found a $350 camry, but not sure if i can fix it Figit090 1st & 2nd Generation (1983–1986 & 1987-1991) 37 01-02-2007 02:29 PM
05 Camry le Trans Fluid Change?? rickytz7111 5th & 6th Generation (2002-2006 & 2007-2011) 5 09-13-2005 07:38 PM
1996 Camry Automatic Transmission Fluid toyteam 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-15-2005 12:52 AM
'97 Camry LE I4 auto N4TECguy Introduce Yourself Here 4 03-30-2004 06:37 PM
